Missing DVD extras from Angel box set
docbill
#1 Post by docbill » Sun Sep 21, 2014 1:53 pm
Normally I've been using makeMKV on blu-ray, but I decided to re-rip the TV series Angel from my box set.
I've noticed each season after I rip everything I'm missing a few of the extra features. For example in Season 4, the previously had encoded extra features of the following length 6:51, 7:58, 39:10, 3:04, 5:42, and 6:06. With makeMKV I only ended up with the first three on this list. I did not see any errors in the output log that accounts for the missing extra features. I watched these features and compared with the others, and these are distinctly separate extra features.
I will probably scan the disks with alternate software to see if I can find one of the disks with a missing extra and determine if there is a pattern. However, before I go through all that effort, I thought I would check if this is a known issue, or if there is some feature that could be filtering these extra features. I have the minimum title length set to 115 seconds, so that would not have filtered these extras.
Bill
Re: Missing DVD extras from Angel box set
#2 Post by Woodstock » Sun Sep 21, 2014 6:34 pm
What do you have set for your minimum title length (Preferences, Video tab, at the bottom)?
MakeMKV will not rip (or even make selectable) titles shorter than that minimum.
ndjamena
#3 Post by ndjamena » Mon Sep 22, 2014 12:03 am
docbill wrote:I have the minimum title length set to 115 seconds, so that would not have filtered these extras.
He'd need to have set it to about 380 to have the effect he's describing.
MakeMKV wouldn't happen to be throwing debug messages at you during scan? Have you checked the log for any discrepancies?
docbill
#4 Post by docbill » Mon Sep 22, 2014 1:14 pm
Based on ordering, I suspected the missing extras for season 4 where on disc 6. Sure enough, that is where I found them. When I open the same disc in DVD Shrink 3.2 it subdivides the titles on that disc under Main Movies as the Title 1, Title 2, Title 3 as the three episodes under the disc. Title 5 is the 39:08 extra. Then under "Extras" I see Title 4 is the 7:58 extra. The three missing extras features are listed as "Title 5 (continued)". So it looks like it is the "continued" tracks parts that are being dropped. I played checked the encoded 39:10 minute video just to be certain it didn't contain these "continued" parts.
So now that I know what to look for, and which discs have the problem, what is the best way to obtain and communicate the data needed to look into this?
Bill
docbill
#5 Post by docbill » Tue Sep 23, 2014 1:20 am
I've included below the log file of the scan with debugging enabled. In this case I've set the minimum time to 0.
Debug log started at Tue Sep 23 01:14:51 2014 , written by MakeMKV v1.8.13 win(x64-release)
001005:0000 MakeMKV v1.8.13 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Bill/MakeMKV_log.txt
003028:0000 Title #1 was added (19 cell(s), 0:41:42)
003028:0000 Title #2 was added (18 cell(s), 0:42:07)
003028:0000 Title #3 was added (18 cell(s), 0:43:04)
003028:0000 Title #4 was added (1 cell(s), 0:07:58)
Title skip vts=2 pgcn=2 hash=30634810CDEF465C
003028:0000 Title #5 was added (5 cell(s), 0:39:07)
Title skip vts=6 pgcn=5 hash=1F98ED2C57C0A619
003028:0000 Title #6 was added (1 cell(s), 0:00:07)
003028:0000 Title #7 was added (1 cell(s), 0:00:16)
Title skip vts=1 pgcn=1 hash=FB65AAE5299B0E30
Application exited at Tue Sep 23 01:16:12 2014
preserve
#6 Post by preserve » Sun Sep 13, 2015 10:43 pm
I'm backing up a lot of my DVDs, and I noticed this problem as well. I was hoping to find a solution here. I love MakeMKV, I don't want to switch to another program.
Let me provide a specific report.
Angel Season 2, Disc 3, Region 1 (Canada / North America).
The featurette "Inside the Agency" that is included on this disc doesn't show up in MakeMKV.
I have my title length set to 2 seconds.
Debug log started at Sun Sep 13 22:34:17 2015 , written by MakeMKV v1.9.5 win(x86-release)
001005:0000 MakeMKV v1.9.5 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as ...
003028:0000 Title #1 was added (24 cell(s), 0:41:37) <- episode
003028:0000 Title #2 was added (25 cell(s), 0:40:31) <- episode
003028:0000 Title #3 was added (23 cell(s), 0:42:02) <- episode
003028:0000 Title #4 was added (2 cell(s), 0:06:38) <- "making up the monsters" featurette
Title skip vts=5 pgcn=1 hash=F263D38E2A3D312B
Title skip vts=5 pgcn=2 hash=2354AD00439C8259
003028:0000 Title #6 was added (1 cell(s), 0:00:07) <- dvd logos / etc
003028:0000 Title #7 was added (1 cell(s), 0:00:16) <- dvd logos / etc
003034:0000 Audio stream #0 looks empty and was skipped
Application exited at Sun Sep 13 22:39:38 2015
Using: ASUS BW-16D1HT 3.00
#7 Post by Woodstock » Mon Sep 14, 2015 12:45 am
In both cases, I think the steps listed in the FAQ in my signature would be a good idea.... Send the log and .IFO files to Mike, using the svq@makemkv.com email address, for him to look at. At the very least, he can give you the manual open control string that will allow the two extra titles to be selectable.
preserve
#8 Post by preserve » Mon Sep 14, 2015 6:11 am
Thank you for the help! Submitted an email, as instructed.
Sigerson
#9 Post by Sigerson » Wed Sep 30, 2015 4:32 pm
Did you get an answer to this? I'm going through the same thing right now with the Angel Box Set.
Thanks.
preserve
#10 Post by preserve » Fri Oct 02, 2015 2:23 am
I sent in the report as instructed, and offered more help if needed - more than happy to go through every disc and list the problems and supply the files for each one - but didn't receive any acknowledgement of the report or hear anything about the status of it.
Sigerson
#11 Post by Sigerson » Wed Oct 07, 2015 4:42 pm
Thanks. :D
RocketFromTheTombs
#12 Post by RocketFromTheTombs » Tue Dec 31, 2019 6:26 pm
preserve wrote: Sun Sep 13, 2015 10:43 pm I'm backing up a lot of my DVDs, and I noticed this problem as well. I was hoping to find a solution here. I love MakeMKV, I don't want to switch to another program.
Did you ever find an answer for this? I am transferring my Angel DVDs now and ran into the exact same issue...
preserve
#13 Post by preserve » Sat Jan 25, 2020 6:48 pm
RocketFromTheTombs wrote: Tue Dec 31, 2019 6:26 pm Did you ever find an answer for this? I am transferring my Angel DVDs now and ran into the exact same issue...
I never heard back from Mike on this, no, re: submitting an email as instructed by Woodstock earlier in the thread.
Since you are having the same issue I guess that nothing has changed in the latest versions of MakeMKV since the time that I was trying this.
I'm more than happy to check all discs and send in IFOs for all discs, if I know that the problem can and will be fixed.
DrOct
#14 Post by DrOct » Tue Nov 02, 2021 12:47 am
Just ran into the exact same problem! Still seems to be happening with this set of DVD's.
elusivezatchmo
#15 Post by elusivezatchmo » Thu Jan 27, 2022 10:53 pm
I'm also having this issue. I just ran into this week were there were two discs in the Angel complete set where I could extract the special features for back up. Has any one found a solution to this?
