Tormented12
#5686 Post by Tormented12 » Fri Oct 29, 2021 1:54 pm
quietvoid wrote: Fri Oct 29, 2021 11:49 am Thanks. I can't reproduce the profile 4 issue with MakeMKV.
Regardless of if the RPU is added with x265 or injected, it always shows profile 7: Codec: MpegH HEVC Main10@L5.1 (dvhe.07.00 BL+RPU)
MKVToolNix (v62) also adds the correct block: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible
By the way, you shouldn't be reencoding unless the RPU is profile 8.
Because the EL would probably be out of sync, and might not even work with 1080p base video.
And keeping a profile 7 RPU makes no sense without the EL.
Thanks for your reply.
What do you mean with the reencoding? Wouldn't it be possible to encode the DV 07.06-> change profile to 08 and inject it back?
As for the profile 7 RPU without the EL, I think I have to check the differences between profiles. What would be ''better'' to use? Convert to profile 08? Since that did work with Bumblebee (somehow 08.03, not 08.06). Is there a difference between 08.03 / 08.06? Another forummer told me I could change the HEX using the HEX-editor to change the profile from 08.03 to 08.06, but I don't know how to use/do that. Any advice what would work best?
quietvoid
#5687 Post by quietvoid » Fri Oct 29, 2021 2:59 pm
Tormented12 wrote: Fri Oct 29, 2021 1:54 pmThanks for your reply.
If you're reencoding just use x265 and the RPU directly: https://x265.readthedocs.io/en/master/c ... vision-rpu
You should just convert to profile 8.
Tormented12 wrote: Fri Oct 29, 2021 1:54 pmAs for the profile 7 RPU without the EL, I think I have to check the differences between profiles. What would be ''better'' to use? Convert to profile 08? Since that did work with Bumblebee (somehow 08.03, not 08.06). Is there a difference between 08.03 / 08.06? Another forummer told me I could change the HEX using the HEX-editor to change the profile from 08.03 to 08.06, but I don't know how to use/do that. Any advice what would work best?
8.03 and 8.06 is just a level difference, because the 03 is 1080p while 06 is 2160p.
With most devices, there's no difference between profile 7 and profile 8, especially if you use MKV.
The hex editing thing only applies for MP4s, you shouldn't have to do anything if you use MKVToolNix v58+.
MakeMKV isn't necesary either, for encodes without an EL.
Tormented12
#5688 Post by Tormented12 » Fri Oct 29, 2021 3:04 pm
quietvoid wrote: Fri Oct 29, 2021 2:59 pm
MakeMKV isn't necesary either.
Thanks for your quick reply! So the 08.03 should be fine now?
I use Ripbotx264 for for the encoding. After I use ffmpeg to get the .mkv -> hevc, and extract the RPU (will extract with mode 2 from now on). Then i change the encoded file from .mkv -> hevc and inject the RPU into the encode. After this I mux to .mkv. Then it just says 'HDR10''. I really have to mux the .mkv file through Makemkv to make the DV 08.03 visible.
quietvoid
#5689 Post by quietvoid » Fri Oct 29, 2021 3:08 pm
Tormented12 wrote: Fri Oct 29, 2021 3:04 pmThanks for your quick reply! So the 08.03 should be fine now?
Yes.
Tormented12 wrote: Fri Oct 29, 2021 3:04 pmI use Ripbotx264 for for the encoding. After I use ffmpeg to get the .mkv -> hevc, and extract the RPU (will extract with mode 2 from now on). Then i change the encoded file from .mkv -> hevc and inject the RPU into the encode. After this I mux to .mkv. Then it just says 'HDR10''. I really have to mux the .mkv file through Makemkv to make the DV 08.03 visible.
You probably have to update your MKVToolNix. Don't use ffmpeg for muxing to MKV.
Also, you can just use ffmpeg without having to demux before extracting the RPU.
Example:
ffmpeg -i input.mkv -c:v copy -vbsf hevc_mp4toannexb -f hevc - | dovi_tool extract-rpu - -o RPU.bin
Tormented12
#5690 Post by Tormented12 » Fri Oct 29, 2021 3:10 pm
quietvoid wrote: Fri Oct 29, 2021 3:08 pm
Yes.
Example:
Somehow I'm getting a error when using that command. Thats why I seperate them. So .mkv -> hevc, after that I use dovi_tool -m 2 extract-rpu video.hevc.
NiCE77
#5691 Post by NiCE77 » Fri Oct 29, 2021 4:22 pm
quietvoid wrote: Fri Oct 29, 2021 11:34 am
NiCE77 wrote: Fri Oct 29, 2021 8:53 am @quietvoid
When I extract RPU from the Enhancement Layer, the resulting RPU length does not match the video length.
Mismatched lengths: video 163840, RPU 128978
This error has occurred in one movie so far.
I can send the sample EL.hevc file if you need via PM.
The EL was probably cut off somehow.
In the past tsMuxer did that, you should try getting it directly from the m2ts with ffmpeg.
I don't need the sample because it wouldn't be very useful unless you're 100% sure it's complete.
Thanks! It's working with ffmpeg!
#5692 Post by RESET_9999 » Fri Oct 29, 2021 5:34 pm
NiCE77 wrote: Fri Oct 29, 2021 4:22 pm
I'm curious, what movie is that?
NiCE77
#5693 Post by NiCE77 » Sat Oct 30, 2021 6:26 am
RESET_9999 wrote: Fri Oct 29, 2021 5:34 pm
Despicable Me 3
NiCE77
#5694 Post by NiCE77 » Mon Nov 01, 2021 6:33 am
I have a problem with another movie: Bumblebee (2018)
When I extract RPU with -m 2 parameter from the EL, and inject the resulted RPU.bin to the reencoded BL, the dolby's mp4muxer does not work with this injected hevc file.
It finishes in less than 1 minute and creates a 0-byte file, however, mkvtoolnix makes a working P8 mkv file.
DennisTheMenace
#5695 Post by DennisTheMenace » Mon Nov 01, 2021 11:03 am
Hi kodi released some new fixes
19.3 version etc....
These new dolby Vision mods, are working better for me on my older ugoos am6 plus
It is a German forum, there are also arm64 versions for the shield tv Pro and FireTv stick versions
https://www.kodinerds.net/index.php/Thr ... /?pageNo=1
right now they are working on a dolby true-hd stutter fix
DennisTheMenace
#5696 Post by DennisTheMenace » Mon Nov 01, 2021 4:46 pm
Atmos sound and dolby Vision (Mel and fel) is working now on my ugoos AM6 plus box in kodi.
But that error that you've to start a movie sometimes still exist.
But that horrible stutter from a long time ago is gone
I have to do some more testing
Edit im getting some short sound dropouts with dolby true-hd atmos every 10 minutes, I hope they can fix this, time will tell
Mattl0
#5697 Post by Mattl0 » Mon Nov 01, 2021 11:55 pm
chros wrote: Fri Sep 24, 2021 2:38 pm
Mattl0 wrote: Fri Sep 24, 2021 10:23 am To get good dv p7 quality on my c1, I need to send stdl (ts or m2ts) to the native com.droidlogic.videoplayer’ player on ugoos6b .
The difference between the native player , and orher player like vimu etc.. is night and day
How do you send video to the native player exactly?
With the ugoos built-in cifs client share. It is seen as a local media for the android system.
I am currently looking to buy a sony blue ray 800 for p7 dolby. I am tired to analyze everything. I want to rip dtdl an be donne with it
deadchip12
#5698 Post by deadchip12 » Tue Nov 02, 2021 12:55 am
Just saw a discussion on avsforums regarding the sony x700 bluray player: Is the dolby vision we get from playing a dolby vision file via usb connected to the x700 tv-led or player-led?
#5699 Post by RESET_9999 » Tue Nov 02, 2021 9:48 pm
DennisTheMenace wrote: Mon Nov 01, 2021 11:03 am Hi kodi released some new fixes
interesting, will try it. thanks
deadchip12 wrote: Tue Nov 02, 2021 12:55 am Just saw a discussion on avsforums regarding the sony x700 bluray player: Is the dolby vision we get from playing a dolby vision file via usb connected to the x700 tv-led or player-led?
it doesn't matter if you play DV content from USB , bluray or streaming apps. The x700 will send the best mode according to your TV EDID.
bobbymkV
#5700 Post by bobbymkV » Wed Nov 03, 2021 12:02 am
DennisTheMenace wrote: Mon Nov 01, 2021 4:46 pm Atmos sound and dolby Vision (Mel and fel) is working now on my ugoos AM6 plus box in kodi.
I'm one of the crazy bastards that purchased an AM6+ lol. Is this the apk you are using then -- https://www.dropbox.com/sh/0n37s3j3iybw ... a.apk?dl=0 ??
I'd like to test.
