Help flashing WH16NS60
Re: Help flashing WH16NS60
Post by Billycar11 » Fri Oct 29, 2021 8:14 pm
grandpixel wrote: Fri Oct 29, 2021 4:49 am Drive 1: Swapping SATA ports fixed the problem. Flashed to 1.02.
Neither drive will flash to 1.00. It says "Programming flash - 100% Operation finished - Done successfully" but still showing 1.02. Well at least I can keep ripping now. Any ideas on getting to 1.00?
ok great so it was the sata controller
what board and port was it on and whats the sata controller?
grandpixel
Post by grandpixel » Mon Nov 01, 2021 5:54 pm
Billycar11 wrote: Fri Oct 29, 2021 8:14 pm ok great so it was the sata controller
Oh boy, I'd have to do some digging on this. Both ports are on the motherboard in the same location with all the other SATA ports. I'd have to dig deeper to figure out if my motherboard actually has more than one SATA controller built-in and which ports are which.
There may be other variables than the SATA controller. I wouldn't know what they are though.
Post by MartyMcNuts » Mon Nov 01, 2021 11:05 pm
grandpixel wrote: Mon Nov 01, 2021 5:54 pm
Look at your MB manual or search for manual online.
Post by Billycar11 » Mon Nov 01, 2021 11:47 pm
Just tell us your motherboard brand and model number
grandpixel
Post by grandpixel » Sat Nov 06, 2021 10:44 pm
Sorry I lost track of this and I don't get notifications. Motherboard is Gigabyte B550I AORUS PRO AX.
grandpixel
Post by grandpixel » Sat Nov 06, 2021 10:51 pm
grandpixel wrote: Sat Nov 06, 2021 10:44 pm Sorry I lost track of this and I don't get notifications. Motherboard is Gigabyte B550I AORUS PRO AX.
No that's not right, sorry. I'm ripping on 2 PC's. This issue occured on my old PC. It's MSI Z68A-GD65 (G3) / MS-7681 VER 4.0
grandpixel
Post by grandpixel » Sat Nov 06, 2021 11:00 pm
Manual says:
2 SATA 6Gb/s ports (SATA1~2) by Intel® Z68
2 SATA 6Gb/s ports (SATA7~8) by Marvell® 9128 (Z68A-GD65 (G3))
4 SATA 3Gb/s ports (SATA3~6) by Intel® Z68
The two cables I swapped were in ports 2 and 8. Sorry but I can't remember which one worked and which didn't.
Post by Billycar11 » Sat Nov 06, 2021 11:02 pm
grandpixel wrote: Sat Nov 06, 2021 11:00 pm Manual says:
Ok that's what I figured it must be the Marvell ports that didn't work I know the Intel 6x series sata controller works for flashing used it for a bit with my 2500k
Thanks for the info
