Tormented12
#5686 Post by Tormented12 » Thu Oct 28, 2021 6:44 pm
I'm facing a new problem with a movie: Bumblebee (2018).
I encoded the movie to 1920x1080p, the movie itself is DV 07.06, so I just extract the RPU (Shield Pro, so it does play). Somehow, when injected into the encode, and afterwards to .mkv and then makemkv, it is DV 04, which it sees as ''SDR''. I don't know why this is happening? When I extract the RPU with mode 2, I will get a DV 08.03 file. If I use mode 0, I also get DV 04. Does anyone know why this is happening with this movie?
quietvoid
#5687 Post by quietvoid » Thu Oct 28, 2021 10:01 pm
Can you provide the RPU file?
It would be weird for the profile to be detected as 4.
Tormented12
#5688 Post by Tormented12 » Fri Oct 29, 2021 5:01 am
https://mega.nz/file/atVkkZQJ#Ghn9_R5Mf ... 8J7Xal5GaA
I have uploaded the RPU.
NiCE77
#5689 Post by NiCE77 » Fri Oct 29, 2021 8:53 am
@quietvoid
When I extract RPU from the Enhancement Layer, the resulting RPU length does not match the video length.
Mismatched lengths: video 163840, RPU 128978
This error has occurred in one movie so far.
I can send the sample EL.hevc file if you need via PM.
quietvoid
#5690 Post by quietvoid » Fri Oct 29, 2021 11:34 am
@quietvoid
The EL was probably cut off somehow.
In the past tsMuxer did that, you should try getting it directly from the m2ts with ffmpeg.
I don't need the sample because it wouldn't be very useful unless you're 100% sure it's complete.
quietvoid
#5691 Post by quietvoid » Fri Oct 29, 2021 11:49 am
Thanks. I can't reproduce the profile 4 issue with MakeMKV.
Regardless of if the RPU is added with x265 or injected, it always shows profile 7: Codec: MpegH HEVC Main10@L5.1 (dvhe.07.00 BL+RPU)
MKVToolNix (v62) also adds the correct block: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible
By the way, you shouldn't be reencoding unless the RPU is profile 8.
Because the EL would probably be out of sync, and might not even work with 1080p base video.
And keeping a profile 7 RPU makes no sense without the EL.
Tormented12
#5692 Post by Tormented12 » Fri Oct 29, 2021 1:54 pm
Thanks for your reply.
What do you mean with the reencoding? Wouldn't it be possible to encode the DV 07.06-> change profile to 08 and inject it back?
As for the profile 7 RPU without the EL, I think I have to check the differences between profiles. What would be ''better'' to use? Convert to profile 08? Since that did work with Bumblebee (somehow 08.03, not 08.06). Is there a difference between 08.03 / 08.06? Another forummer told me I could change the HEX using the HEX-editor to change the profile from 08.03 to 08.06, but I don't know how to use/do that. Any advice what would work best?
quietvoid
#5693 Post by quietvoid » Fri Oct 29, 2021 2:59 pm
If you're reencoding just use x265 and the RPU directly: https://x265.readthedocs.io/en/master/c ... vision-rpu
You should just convert to profile 8.
8.03 and 8.06 is just a level difference, because the 03 is 1080p while 06 is 2160p.
With most devices, there's no difference between profile 7 and profile 8, especially if you use MKV.
The hex editing thing only applies for MP4s, you shouldn't have to do anything if you use MKVToolNix v58+.
MakeMKV isn't necesary either, for encodes without an EL.
Tormented12
#5694 Post by Tormented12 » Fri Oct 29, 2021 3:04 pm
MakeMKV isn't necesary either.
Thanks for your quick reply! So the 08.03 should be fine now?
I use Ripbotx264 for for the encoding. After I use ffmpeg to get the .mkv -> hevc, and extract the RPU (will extract with mode 2 from now on). Then i change the encoded file from .mkv -> hevc and inject the RPU into the encode. After this I mux to .mkv. Then it just says 'HDR10''. I really have to mux the .mkv file through Makemkv to make the DV 08.03 visible.
quietvoid
#5695 Post by quietvoid » Fri Oct 29, 2021 3:08 pm
Yes.
You probably have to update your MKVToolNix. Don't use ffmpeg for muxing to MKV.
Also, you can just use ffmpeg without having to demux before extracting the RPU.
Example:
ffmpeg -i input.mkv -c:v copy -vbsf hevc_mp4toannexb -f hevc - | dovi_tool extract-rpu - -o RPU.bin
Tormented12
#5696 Post by Tormented12 » Fri Oct 29, 2021 3:10 pm
Yes.
Example:
Somehow I'm getting a error when using that command. Thats why I seperate them. So .mkv -> hevc, after that I use dovi_tool -m 2 extract-rpu video.hevc.
NiCE77
#5697 Post by NiCE77 » Fri Oct 29, 2021 4:22 pm
@quietvoid
Thanks! It's working with ffmpeg!
#5698 Post by RESET_9999 » Fri Oct 29, 2021 5:34 pm
I'm curious, what movie is that?
NiCE77
#5699 Post by NiCE77 » Sat Oct 30, 2021 6:26 am
Despicable Me 3
NiCE77
#5700 Post by NiCE77 » Mon Nov 01, 2021 6:33 am
I have a problem with another movie: Bumblebee (2018)
When I extract RPU with -m 2 parameter from the EL, and inject the resulted RPU.bin to the reencoded BL, the dolby's mp4muxer does not work with this injected hevc file.
It finishes in less than 1 minute and creates a 0-byte file, however, mkvtoolnix makes a working P8 mkv file.
