Yes.Tormented12 wrote: Fri Oct 29, 2021 3:04 pmThanks for your quick reply! So the 08.03 should be fine now?
You probably have to update your MKVToolNix. Don't use ffmpeg for muxing to MKV.Tormented12 wrote: Fri Oct 29, 2021 3:04 pmI use Ripbotx264 for for the encoding. After I use ffmpeg to get the .mkv -> hevc, and extract the RPU (will extract with mode 2 from now on). Then i change the encoded file from .mkv -> hevc and inject the RPU into the encode. After this I mux to .mkv. Then it just says 'HDR10''. I really have to mux the .mkv file through Makemkv to make the DV 08.03 visible.
Also, you can just use ffmpeg without having to demux before extracting the RPU.
Example:
ffmpeg -i input.mkv -c:v copy -vbsf hevc_mp4toannexb -f hevc - | dovi_tool extract-rpu - -o RPU.bin
