Failing for me on the mac
Debug log started at Tue Feb 22 02:09:04 2011 , written by MakeMKV v1.6.5 darwin(x86-release)
001005:0000 MakeMKV v1.6.5 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/terry/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-875 DB09" opened in DASPI mode.
002014:0000 Optical drive "BD-ROM ATAPI iHOS104 WL0B" opened in DASPI mode.
001003:0020 DEBUG: Code 0 at +>@PH894}5 iZK1(:29399588
001003:0020 DEBUG: Code 117572395 at K|cLd{ope%9ew1RFdJ:29394321
001003:0020 DEBUG: Code 117572395 at K|cLd{ope%9ew1RFdJ:29395885
001003:0020 DEBUG: Code 117572395 at K|cLd{ope%9ew1RFdJ:121262049
002003:0000 Error 'Internal error - Input parameter is incorrect (811)' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-875 DB09' at offset '524288'
002003:0000 Error 'Internal error - Input parameter is incorrect (811)' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-875 DB09' at offset '1048576'
001003:0020 DEBUG: Code 117572395 at K|cLd{ope%9ew1RFdJ:213132560
002003:0000 Error 'Internal error - Input parameter is incorrect (811)' occurred while reading 'DVD+R-DL MATSHITA DVD-R UJ-875 DB09' at offset '32768'
001003:0020 DEBUG: Code 0 at ?hyY!pY\qW%1 nGi$k?:29393447
DISCID=5FB8981FC0AA341EDD11323F5E6A59DB82DE2EC1
003307:0000 File 00036.mpls was added as title #0
003307:0000 File 00037.mpls was added as title #1
003025:0000 Title #00045.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00044.mpls was added as title #2
003025:0000 Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00044.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00047.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00048.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00049.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00056.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00057.m2ts was added as title #3
003307:0000 File 00058.m2ts was added as title #4
003025:0000 Title #00074.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00076.m2ts was added as title #5
005014:0000 Saving 1 titles into directory /Volumes/Bluray backup4
001003:0020 DEBUG: Code 30 at *(OBj9+rD7"8r&p478LyDh:29393677
005003:0000 Failed to save title 0 to file /Volumes/Bluray backup4/title00.mkv
005004:0080 0 titles saved, 1 failed
Oceans 11
Re: Oceans 11
Program failed to create output file, please check free space and permissions.
