Makemkv is just adding the dvhe flag, in profile 7 and 8 you can do this quickly with a hex editor, it is in the linked to guide on the previous page.mattmarsden wrote: ↑Wed Oct 27, 2021 4:33 pmTry running the muxed mkv through MakeMKVTormented12 wrote: ↑Tue Oct 26, 2021 4:26 pmI have a question regarding encoding a file to 1920x1080p and add the Dolby Vision later. Somehow, I don't get the right file after RPU insertion.
I have encoded a Game of Thrones Episode (4K REMUX, which is Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU). I encoded it without cropping, (which I do for every encode, also movies, I just resize it from 3840x2160 to 1920x1080).
It got me an 1080p episode, which is HDR10. I used the following command to change the .mkv file to hevc:
ffmpeg -y -i GOT.S01E01.mkv -an -c:v copy -f hevc GOT.S01E01.hevc
After this, I use the command to extract the RPU from the HEVC with mode 2:
dovi_tool -m 2 extract-rpu GOT.S01E01.hevc, which gives me an RPU.bin, which, I think should be converted to profile 8.
After this, I use the ffmpeg command to change the re-encoded file from .mkv file to hevc.file. I then usethe following command to inject the RPU into the re-encoded HEVC.file:
dovi_tool inject-rpu -i GOT.S01E01.HDR.hevc --rpu-in RPU.bin -o injected_output.hevc
But somehow, I doesn't work for me. It keeps begin SMPTE 2086, HDR10. Dolby Vision won't be visible in the hevc output file. When I mux the hevc.file to .mkv, then it still is only HDR10, and not Dolby Vision.
What is the part where I screw up? I'm doing it somewhere, but I just can't put my finger on it. Or is it a cropping thing? Some help with this would be very appreciated!
Regards,
Tormented12
I'm facing a new problem with a movie: Bumblebee (2018).
I encoded the movie to 1920x1080p, the movie itself is DV 07.06, so I just extract the RPU (Shield Pro, so it does play). Somehow, when injected into the encode, and afterwards to .mkv and then makemkv, it is DV 04, which it sees as ''SDR''. I don't know why this is happening? When I extract the RPU with mode 2, I will get a DV 08.03 file. If I use mode 0, I also get DV 04. Does anyone know why this is happening with this movie?
Can you provide the RPU file?Tormented12 wrote: ↑Thu Oct 28, 2021 6:44 pmI'm facing a new problem with a movie: Bumblebee (2018).
It would be weird for the profile to be detected as 4.
@quietvoid
When I extract RPU from the Enhancement Layer, the resulting RPU length does not match the video length.
Mismatched lengths: video 163840, RPU 128978
This error has occurred in one movie so far.
I can send the sample EL.hevc file if you need via PM.
The EL was probably cut off somehow.NiCE77 wrote: ↑Fri Oct 29, 2021 8:53 am@quietvoid
In the past tsMuxer did that, you should try getting it directly from the m2ts with ffmpeg.
I don't need the sample because it wouldn't be very useful unless you're 100% sure it's complete.
Thanks. I can't reproduce the profile 4 issue with MakeMKV.Tormented12 wrote: ↑Fri Oct 29, 2021 5:01 amhttps://mega.nz/file/atVkkZQJ#Ghn9_R5Mf ... 8J7Xal5GaA
I have uploaded the RPU.
Regardless of if the RPU is added with x265 or injected, it always shows profile 7: Codec: MpegH HEVC Main10@L5.1 (dvhe.07.00 BL+RPU)
MKVToolNix (v62) also adds the correct block: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible
By the way, you shouldn't be reencoding unless the RPU is profile 8.
Because the EL would probably be out of sync, and might not even work with 1080p base video.
And keeping a profile 7 RPU makes no sense without the EL.
Thanks for your reply.quietvoid wrote: ↑Fri Oct 29, 2021 11:49 amThanks. I can't reproduce the profile 4 issue with MakeMKV.
What do you mean with the reencoding? Wouldn't it be possible to encode the DV 07.06-> change profile to 08 and inject it back?
As for the profile 7 RPU without the EL, I think I have to check the differences between profiles. What would be ''better'' to use? Convert to profile 08? Since that did work with Bumblebee (somehow 08.03, not 08.06). Is there a difference between 08.03 / 08.06? Another forummer told me I could change the HEX using the HEX-editor to change the profile from 08.03 to 08.06, but I don't know how to use/do that. Any advice what would work best?
If you're reencoding just use x265 and the RPU directly: https://x265.readthedocs.io/en/master/c ... vision-rpuTormented12 wrote: ↑Fri Oct 29, 2021 1:54 pmThanks for your reply.
You should just convert to profile 8.
8.03 and 8.06 is just a level difference, because the 03 is 1080p while 06 is 2160p.Tormented12 wrote: ↑Fri Oct 29, 2021 1:54 pmAs for the profile 7 RPU without the EL, I think I have to check the differences between profiles. What would be ''better'' to use? Convert to profile 08? Since that did work with Bumblebee (somehow 08.03, not 08.06). Is there a difference between 08.03 / 08.06? Another forummer told me I could change the HEX using the HEX-editor to change the profile from 08.03 to 08.06, but I don't know how to use/do that. Any advice what would work best?
With most devices, there's no difference between profile 7 and profile 8, especially if you use MKV.
The hex editing thing only applies for MP4s, you shouldn't have to do anything if you use MKVToolNix v58+.
MakeMKV isn't necesary either, for encodes without an EL.
Thanks for your quick reply! So the 08.03 should be fine now?quietvoid wrote: ↑Fri Oct 29, 2021 2:59 pmIf you're reencoding just use x265 and the RPU directly: https://x265.readthedocs.io/en/master/c ... vision-rpuTormented12 wrote: ↑Fri Oct 29, 2021 1:54 pmThanks for your reply.
MakeMKV isn't necesary either.
I use Ripbotx264 for for the encoding. After I use ffmpeg to get the .mkv -> hevc, and extract the RPU (will extract with mode 2 from now on). Then i change the encoded file from .mkv -> hevc and inject the RPU into the encode. After this I mux to .mkv. Then it just says 'HDR10''. I really have to mux the .mkv file through Makemkv to make the DV 08.03 visible.
Yes.Tormented12 wrote: ↑Fri Oct 29, 2021 3:04 pmThanks for your quick reply! So the 08.03 should be fine now?
You probably have to update your MKVToolNix. Don't use ffmpeg for muxing to MKV.Tormented12 wrote: ↑Fri Oct 29, 2021 3:04 pmI use Ripbotx264 for for the encoding. After I use ffmpeg to get the .mkv -> hevc, and extract the RPU (will extract with mode 2 from now on). Then i change the encoded file from .mkv -> hevc and inject the RPU into the encode. After this I mux to .mkv. Then it just says 'HDR10''. I really have to mux the .mkv file through Makemkv to make the DV 08.03 visible.
Also, you can just use ffmpeg without having to demux before extracting the RPU.
Example:
ffmpeg -i input.mkv -c:v copy -vbsf hevc_mp4toannexb -f hevc - | dovi_tool extract-rpu - -o RPU.bin
Somehow I'm getting a error when using that command. Thats why I seperate them. So .mkv -> hevc, after that I use dovi_tool -m 2 extract-rpu video.hevc.quietvoid wrote: ↑Fri Oct 29, 2021 3:08 pmYes.Tormented12 wrote: ↑Fri Oct 29, 2021 3:04 pmThanks for your quick reply! So the 08.03 should be fine now?
Example:Code: Select all
Thanks! It's working with ffmpeg!quietvoid wrote: ↑Fri Oct 29, 2021 11:34 amThe EL was probably cut off somehow.NiCE77 wrote: ↑Fri Oct 29, 2021 8:53 am@quietvoid
I'm curious, what movie is that?
Despicable Me 3
