makemkv couldn't handle the Redbox version, volume key unknown.
emailed MKB20_v76_The_Suicide_Squad_CA7E.tgz to svq@makemkv.com
The Suicide Squad (2021)
Re: The Suicide Squad (2021)
already fixed when I tried it today, thanks for the quick turnaround Mike!
incidentally there are two different branches of the movie here.
the only difference is the opening credits scene, one uses segment 76, the other segment 87. I can't see a difference between the two though!
It is similar on the regular blu-ray: viewtopic.php?f=8&t=26356
Anyone ripped this as a backup and had problems with bdmv_modify_v1.4 not fixing it.
Just reports ???????? in a message box.
Re did this on another device and BDMV_MOD said it worked.
However it does not play, it looks to start but just has a black screen. I have to press stop and it returns back to the folder name for the film.
