I've seen it but couldn't figure out how to check my drive if it has these known encrypted firmwares or not. Do you know how I would do that?d00zah wrote: Mon Oct 04, 2021 11:49 pmThe 1st post in this thread has a list of known encrypted FWs (& MANY other things) . It remains the "definitive guide" on this topic.Zimonio wrote: Mon Oct 04, 2021 5:16 pm Sorry if this has been asked but how do I find out if my drive has encrypted or unencrypted firmware? I just got the Asus BW-16D1HT and want to flash it but I can't figure out if I should use the cmd prompt with the "enc" extension or not.
Zimonio
Re: Ultimate UHD Drives Flashing Guide Updated 2021
if sdf tool is not working just use the command line commands and my video thats why i have both up martys sdf tool should always be tried first but if that fails you can do it direct with cmd.Zimonio wrote: Tue Oct 05, 2021 7:31 am
your firmware is not encrypted dont use enc
Zimonio
Got it to work, thank you!Billycar11 wrote: Tue Oct 05, 2021 8:18 am if sdf tool is not working just use the command line commands and my video thats why i have both up matys sdf tool should always be tried first but if that fails you can do it direct with cmd.
Roerich
Whoops posted in the wrong thread
compulov
Just wanted to send a thanks to everyone involved in creating the guide, the flasher, and the modified firmwares. I was able to purchase the right drive, the right external enclosure, and find the right firmware and flash it with little fanfare. Now I can rip the UHD disks I have sitting here in my family room.
Stellan
Thanks! Had almost given up, then I used this guide "https://www.youtube.com/watch?v=jyQV1aPlbow" and it worked perfectly!
lidejia
Hello everyone.
I tried to flash the drive firmware in order to enable LibreDrive, but unfortunately it failed with the following message:
I tried this on windows and linux, but none of them work. I also tried the GUI tool, but the same error code pop up.
The following is my drive information
Any ideas on how to solve this issue? Thanks very much.
makemkvcon f --all-yes -d /dev/sr0 -v rawflash -i ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BH16NS60/HL-DT-ST-BD-RE_BH16NS60-1.02-NM00600-212005081014.bin
Loaded SDF.bin version 0x7e
Reading input file ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BH16NS60/HL-DT-ST-BD-RE_BH16NS60-1.02-NM00600-212005081014.bin
Current Drive ID: HL-DT-ST_BD-RE__BH16NS60_1.01_211901041419_KLJJ6OA2118
Write flags NG 05/FF/03
Command produced error code 0x8f05ff03
OS device name: /dev/sr0
Product: BD-RE BH16NS60
Revision: 1.01
Firmware date: 2119-01-04 14:19
Bus encryption flags: 1F
Highest AACS version: 76
Please try the newest flasher 1.2.2 from here and make sure the tray is closed and you have no disc in the drive.
viewtopic.php?f=16&t=22896&start=315
lidejia
Thanks for the response. I already tried that tool, but doesn't work. I am able to dump the firmware, but the write will fail with the same error as I posted beforeCoopervid wrote: Tue Oct 12, 2021 4:41 pm Please try the newest flasher 1.2.2 from here and make sure the tray is closed and you have no disc in the drive.
lidejia
I was able to flash the firmware after using this legacy flasher: viewtopic.php?f=16&t=18873#p70284lidejia wrote: Tue Oct 12, 2021 1:09 pm Hello everyone.
I tried this on windows and linux, but none of them work. I also tried the GUI tool, but the same error code pop up.Code: Select all
makemkvcon f --all-yes -d /dev/sr0 -v rawflash -i ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BH16NS60/HL-DT-ST-BD-RE_BH16NS60-1.02-NM00600-212005081014.bin Loaded SDF.bin version 0x7e Reading input file ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BH16NS60/HL-DT-ST-BD-RE_BH16NS60-1.02-NM00600-212005081014.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Current Drive ID: HL-DT-ST_BD-RE__BH16NS60_1.01_211901041419_KLJJ6OA2118 Write flags NG 05/FF/03 Command produced error code 0x8f05ff03
The following is my drive informationAny ideas on how to solve this issue? Thanks very much.Code: Select all
Drive Information OS device name: /dev/sr0 Manufacturer: HL-DT-ST Product: BD-RE BH16NS60 Revision: 1.01 Firmware date: 2119-01-04 14:19 Bus encryption flags: 1F Highest AACS version: 76 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 No disc inserted
habbywall
Started trying this again to get my 4k UHD discs to rip, still having some issues. Running on a headless ubuntu server. Running with or without enc command gives the same error. This is on a LG WH16NS60.
Running the following command:
Getting the following error:
Is there a command I can run to give better diagnostics as to what my disc is for better searching/troubleshooting
makemkvcon f --all-yes -d /dev/sr0 rawflash enc -i mkvfirmware/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file mkvfirmware/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLNL26E4242
DEBUG: Code 4280012805 at Mx=Q{%DdK23UWRSK}6/xi^l-6'?wWl*&:121264648
Command produced error code 0x8f1bd005
thinksinc
Could someone help walk me through the steps to flash my Buffalo BRUHD-PU3-BK to work with MakeMKV?
I tried following the guides but it's a little overwhelming with so many options. I downloaded the SDFTool Flasher and the "All You Need Firmware Pack", but I'm not sure which firmware file I should use with this Buffalo drive.
Appreciate any help.
Thanks.
Thanks.
It's a BU40N just follow thatthinksinc wrote: Thu Oct 28, 2021 3:05 am Could someone help walk me through the steps to flash my Buffalo BRUHD-PU3-BK to work with MakeMKV?
Thanks.
OpaKopalke
No flashing needed._nmd_ wrote: Sat Oct 02, 2021 12:47 am I just got a BH16NS40 / SVC:NS51, here's the information I get:
Product: BD-RE BH16NS40
Revision: 1.02
Serial number: (hidden)
Firmware date: 2115-12-11 14:36
Highest AACS version: 68
Firmware version: 1.02
From this information, do I still have to flash in order to read UHD disks, or is it actually unneeded (as everything is marked OK)? I thought flashing was necessary for all UHD friendly drives, but I'm not sure how to interpret this report...
I don't have UHD disks yet (was waiting to have an enabled drive before I'd start buying), otherwise I'd already be testing of course.
You could flash the WH16NS60 1.02 MK for higher read speeds. Read the flash guide where to find the firmware pack
kuro2K20
If I buy an LG BH16NS55, I am sure it will be UHD compatible ? (after flashing with WH16NS60 1.02MK firmware...)
Will I then be able to burn BD-R/RE or it will be blocked and in fact, I will only be able to read my BRD and BRD UHD ?
