mattmarsden
Post by mattmarsden » Wed Oct 27, 2021 4:33 pm
Tormented12 wrote:
Tue Oct 26, 2021 4:26 pm
I have a question regarding encoding a file to 1920x1080p and add the Dolby Vision later. Somehow, I don't get the right file after RPU insertion.
I have encoded a Game of Thrones Episode (4K REMUX, which is Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU). I encoded it without cropping, (which I do for every encode, also movies, I just resize it from 3840x2160 to 1920x1080).
It got me an 1080p episode, which is HDR10. I used the following command to change the .mkv file to hevc:
ffmpeg -y -i GOT.S01E01.mkv -an -c:v copy -f hevc GOT.S01E01.hevc
After this, I use the command to extract the RPU from the HEVC with mode 2:
dovi_tool -m 2 extract-rpu GOT.S01E01.hevc, which gives me an RPU.bin, which, I think should be converted to profile 8.
After this, I use the ffmpeg command to change the re-encoded file from .mkv file to hevc.file. I then usethe following command to inject the RPU into the re-encoded HEVC.file:
dovi_tool inject-rpu -i GOT.S01E01.HDR.hevc --rpu-in RPU.bin -o injected_output.hevc
But somehow, I doesn't work for me. It keeps begin SMPTE 2086, HDR10. Dolby Vision won't be visible in the hevc output file. When I mux the hevc.file to .mkv, then it still is only HDR10, and not Dolby Vision.
What is the part where I screw up? I'm doing it somewhere, but I just can't put my finger on it. Or is it a cropping thing? Some help with this would be very appreciated!
Regards,
Tormented12
Try running the muxed mkv through MakeMKV
Tormented12
Post by Tormented12 » Wed Oct 27, 2021 6:12 pm
It worked. It now has the following in MediaInfo:
Dolby Vision, Version 1.0, dvhe.08.03, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Is this the right profile? Sometimes I see 08.06? If I encode 3840x2160 -> 1920x1080 without cropping, will I need to use the cropping feature from dovi_tool? Or wont it matter to use if the encode isn't cropped? And if so, do I manually need to set the cropping offsets?
BetaExorcist
Post by BetaExorcist » Wed Oct 27, 2021 8:41 pm
I am trying to get the DV8 + HDR10 BL single layer with the yuesope's tool and I keep getting the same error:
Exception in thread Thread-5:SIS: 0.0% BL_EL_RPU WRITING: 0.0% (BL AUs: 105 EL AUs: 52)
Traceback (most recent call last):
File "E:\Video\Dolby Vision\v0.0.4_BETA_TEST_FEL_TO_MEL_PLUS_UHDBD_TO_81__PLUS_SKIP_HDR10plus__PLUS_EXPERIM_MUXER_17102020\python-3.7.6.amd64\lib\threading.py", line 926, in _bootstrap_inner
self.run()
File "src\app.py", line 929, in run
self.write(access_unit)
File "src\app.py", line 912, in write
nalu.data.prepend("0x00000001")
AttributeError: 'int' object has no attribute 'prepend'
BL_ANALYSIS: 0.0% EL_ANALYSIS: 0.0% BL_EL_RPU WRITING: 0.0% (BL AUs: 124 EL AUs: 52)
BL_ANALYSIS: 0.0% EL_ANALYSIS: 0.0% BL_EL_RPU WRITING: 0.0% (BL AUs: 515 EL AUs: 502)
and when I try to use the Dovi tool I get this message:
E:\Video\Dolby Vision\dovi_tool-1.1.3-x86_64-pc-windows-msvc\dist>dovi_tool -m 2 extract-rpu EL_RPU.hevc
thread 'main' panicked at 'called `Option::unwrap()` on a `None` value', C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\hevc_parser-0.2.0\src\hevc\slice.rs:39:55
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
I was wondering if anyone knows how to fix this or if there is something else I can use?
powdeau
Post by powdeau » Wed Oct 27, 2021 9:22 pm
quietvoid wrote:
Wed Oct 20, 2021 1:26 pm
powdeau wrote:
Wed Oct 20, 2021 11:28 am
Hi, is it somehow possible to convert profile 8 to profile 5?
No. Are you sure your TV doesn't support profile 8?
It works on the C8 with ts files.
So I've tried using mp4muxer and I've converted this mkv file:
Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
to this mp4 file:
Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
The mp4 file plays fine on my LG C7 and even the DV logo is displayed. Is it possible it could work or do I just get some sort of fake DV?
quietvoid
Post by quietvoid » Wed Oct 27, 2021 10:12 pm
I don't know. You could try remuxing the file here: viewtopic.php?p=113537#p113537
In the same way, if you see changes then it should probably work.
powdeau
Post by powdeau » Wed Oct 27, 2021 10:26 pm
Yes! I can see the changes.
Thank you for your help!
Post by RESET_9999 » Wed Oct 27, 2021 10:46 pm
What's up with the new Firetv stick? I don't know if it was the same with the older one but here's what I'm noticing:
1- no 24fps support on plex ... 23.976fps is fine
2- if display settings are set to '' AUTO 4k max '' then everything that is not 4k plays in 1080p on plex. (no upscale to 4k )
3- if display settings are set to 2160p 60hz, then 1080p videos are played in 4k but then the framerate match doesn't work anymore on plex
4- display settings ''AUTO 4K max'' , 4k movies on iTunes/appleTV plays in 1080p
5- display settings '' 2160p 60hz'' , DV movies play in HDR10 4K on itunes.
6- frame rate match doesn't work at all on iTunes.
in fact , it looks like only the amazon prime app works properly. I don't have a Netflix account.
quietvoid
Post by quietvoid » Wed Oct 27, 2021 11:00 pm
1- I played a 1080p24 file and Plex matched it to 24Hz, confirmed with System X-Ray. HDMI set to 24Hz.
My display settings are set to Auto.
2- Played a 720p25 file and it is sent as 720p50 to the TV.
Are you sure you're matching the resolution as well in Plex?
3- I'm pretty sure not setting to Auto makes the OS hide the different refresh rate modes, it was the same on the 2018 with Kodi at least.
Netflix logged me out so I don't want to bother trying it, but I'm pretty sure it did 2160p.
Post by RESET_9999 » Wed Oct 27, 2021 11:05 pm
1- will test another file, but the one I tried played in 23.976fps according to my vertex.
2- didn't try 25fps content (not sure if I even have some) but yes, both firestick and plex settings have the frame rate match on. Resolution match, I tried both but will try again, I'm not sure
3- yep, once you're not on ''auto'', framerate match becomes greyed out.
quietvoid
Post by quietvoid » Wed Oct 27, 2021 11:06 pm
The Android Plex app has two settings, one for the refresh rate, the other for the resolution.
At least for me.
Post by RESET_9999 » Wed Oct 27, 2021 11:08 pm
At least for me.
yeah sorry I misread your post.
Yes, I think I tried the resolution match on and off. but will try again, not 100% sure
Post by RESET_9999 » Wed Oct 27, 2021 11:24 pm
ok so I tried with plex resolution match on ... this makes the TV switch to 720p for 720p video but it stays in 1080p for 4k videos ...
So I guess the right setting is ''off '' but still no 4k for non-4k video if the firestick display setting is ''auto 4k max''
Tried another 24fps video and still got 23.976
tried 29.970fps video and got 60fps.
chestnut man 24fps
quietvoid
Post by quietvoid » Thu Oct 28, 2021 1:54 am
I remembered I did post about this before: https://www.avsforum.com/threads/offici ... t-61099898
So it's weird for it not to upscale at all for you..
Although I can't remember if I did that test on the new 4K Max.
DaMacFunkin
Post by DaMacFunkin » Thu Oct 28, 2021 5:30 am
Regards,
Tormented12
Makemkv is just adding the dvhe flag, in profile 7 and 8 you can do this quickly with a hex editor, it is in the linked to guide on the previous page.
Tormented12
Post by Tormented12 » Thu Oct 28, 2021 6:44 pm
I'm facing a new problem with a movie: Bumblebee (2018).
I encoded the movie to 1920x1080p, the movie itself is DV 07.06, so I just extract the RPU (Shield Pro, so it does play). Somehow, when injected into the encode, and afterwards to .mkv and then makemkv, it is DV 04, which it sees as ''SDR''. I don't know why this is happening? When I extract the RPU with mode 2, I will get a DV 08.03 file. If I use mode 0, I also get DV 04. Does anyone know why this is happening with this movie?
