I have reinstalled makemkv with the new version (old deinstall via installer). Under Info I see that the version still runs for 7 days (Nov 2), but when I want to open a file I get the message that the license has expired.
I am grateful for any tips or advice.
Software update does not generate a new key
Re: Software update does not generate a new key
There is one active beta key at any point in time. It is not generated by the program on installation; it is included in the install file.
If a version has been out for more than 60 days, the included key will expire.
The current beta key will always be here:
viewtopic.php?f=5&t=1053
That message also lists when the listed key expires.
mnick
Thank you very much. It works.
