Amazing help, thanks so much. In a couple of days I'm going to be asking you about injecting the MADVR created metadata as DV!!
Do you know how I can enter a "min_display_mastering_luminance" vlaue of 0.005? It doesn't seem to like that - it only want whole numbers. I've used 0 which I think must be close enough!RESET_9999 wrote: ↑Sat Oct 23, 2021 6:26 pm1- extract HDR10+ into a jsonmattmarsden wrote: ↑Sat Oct 23, 2021 5:46 pmThanks for that. Is there an idiots guide on HDR10+ to DV conversion?2- create a json with L6 metadata (static HDR metadata: match your source)Code: Select all
hdr10plus_parser.exe -i X:\HDR10+.hevc -o X:\HDR10+.json
3- generate DV metadataCode: Select all
{ "length": 0, "level6": { "max_display_mastering_luminance": 1000, "min_display_mastering_luminance": 50, "max_content_light_level": 0, "max_frame_average_light_level": 0 } }
4- inject DV metadataCode: Select all
dovi_tool.exe generate --hdr10plus-json X:\HDR10+.json --json X:\L6.json --rpu-out X:\DVrpu.bin
https://github.com/quietvoid/dovi_toolCode: Select all
dovi_tool.exe inject-rpu -i X:\HDR10+.hevc --rpu-in X:\DVrpu.bin
https://github.com/quietvoid/hdr10plus_tool
my json example is 0.0050mattmarsden wrote: ↑Sun Oct 24, 2021 7:33 am
Ah OK - it says 50, am I reading it wrong?RESET_9999 wrote: ↑Sun Oct 24, 2021 1:10 pmmy json example is 0.0050mattmarsden wrote: ↑Sun Oct 24, 2021 7:33 am
The value in the RPU should be multiplied by 10 000*, for the min.
So the common values: 0.0001 = 1, 0.0050 = 50, etc.
Make that 10 000.mattmarsden wrote: ↑Mon Oct 25, 2021 2:14 pmSorry to keep going on about this but 0.0050 x 1000 = 5 - is 50 definitely correct for the value?
Great, thanks - just checking I got it right!quietvoid wrote: ↑Mon Oct 25, 2021 2:29 pmMake that 10 000.mattmarsden wrote: ↑Mon Oct 25, 2021 2:14 pmSorry to keep going on about this but 0.0050 x 1000 = 5 - is 50 definitely correct for the value?
Wow, this HDR10+ -> DV stuff seems pretty amazing
It seems to work on Amazons streaming content as well, based on a quick test. However i don't currently have anything i really want to watch through to check, but i'll definitely put some new episodes of The Expanse through this procedure when they arrive (december i believe)
I looked at the guide on avsforum but I am having a little trouble with the installing from the Dolby labs GitHub do you think you could explain the installation process or know of some clear documentation or video that can help? I got as far as devenv mp4muxer_2010.sln /Rebuild but I got 2 errors one of which is a fatal one and I am not even sure I am doing it right in the first place.staknhalo wrote: ↑Sat Oct 23, 2021 6:24 pmI wrote up how this idiot does it here:mattmarsden wrote: ↑Sat Oct 23, 2021 5:46 pmThanks for that. Is there an idiots guide on HDR10+ to DV conversion?
https://www.avsforum.com/threads/author ... t-60952335
Turn HDR10+ metadata into Dolby Vision metadata**
Command 1: 'hdr10plus_tool extract Video.hevc -o Metadata.json' (Extracts HDR10+ metadata and saves to .json file)
>>Next commands go through Dovi_Tool and v0.5.0 minimum required<<<
Command 2: 'dovi_tool generate -j Extra.json --hdr10plus-json Metadata.json --rpu-out RPUPlus.bin' (combines metadata from edited 'Extra.json' - template is below and you need to do one for every title specifically - and metadata from extracted 'Metadata.json' and combines+converts them into p8 RPU metadata format)
Command 3: 'dovi_tool.exe inject-rpu --input Video.hevc --rpu-in RPUPlus.bin' (Injects HDR10+ generated RPU metadata into HEVC stream turning it into single layer Dolby Vision 8 stream)
Blank Template for 'Extra.json'
"length": (title specific framelength here without parenthesis),
"level2": [
"target_nits": 100
"target_nits": 600
"target_nits": 1000
"target_nits": 2000
"level6": {
"max_display_mastering_luminance": (title specific metadata info here without parenthesis),
"min_display_mastering_luminance": (title specific metadata info here without parenthesis),
"max_content_light_level": (title specific metadata info here without parenthesis),
"max_frame_average_light_level": (title specific metadata info here without parenthesis)
error 1: 1>..\..\..\src\mp4_muxer.c : error C4335: Mac file format detected: please convert the source file to either DOS or UNIX format
fatal error: 2>LINK : fatal error LNK1104: cannot open file '<path>\dlb_mp4base\make\mp4muxer\windows_amd64\debug\VS2010\libmp4base.lib'
Hello All,
i would like to reduce dolvby vision (profile 5) mp4 file from 9GB to ~3GB by re-encode video in Staxrip.
My file mediainfo looks like below:
Video
Format : HEVC
Format profile : Main 10@L5.2@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Duration : 25 min 4 s
Bit rate : 22.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.112
Stream size : 3.92 GiB (99%)
Default : Yes
Alternate group : 1
Encoded date : UTC 2021-06-18 06:42:54
Tagged date : UTC 2021-06-18 06:43:27
Color range : Full
Codec configuration box : hvcC+dvcC
what i did to reduce video file size is:
1) extra DV profile 5 by this command:
ffmpeg.exe -i DV_TEST.mp4 -c:v copy -vbsf hevc_mp4toannexb -f hevc - | dovi_tool.exe extract-rpu - -o RPU.bin
2) Setup StaxRip x265 encoder with Profile 5 and path to RPU.bin
3) After re-encode is done i mux hevc to mp4 by executing this command:
mp4muxer.exe --dv-profile 5 --input-file DV_TEST.mp4 --output-file mp4muxer_out.mp4
4) Add audio.eac3 and subtitles are done by this command:
mp4box.exe -add mp4muxer_out.mp4 -add audio.eac3 mp4box_out.mp4
and i got file like below:
Video
Format : HEVC
Codec ID : hvc1
Duration : 2 min 59 s
Source duration : 3 min 0 s
Bit rate : 21.1 Mb/s
Maximum bit rate : 38.8 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.106
Stream size : 454 MiB (99%)
Source stream size : 454 MiB (99%)
Default : Yes
Alternate group : 1
Tagged date : UTC 2021-10-22 17:05:16
Color range : Full
but when i try play it on my LG oled 55b7v TV from usb drive dolby vision is recognized but when try to move forward it stops play this file and start plays next one.
Could someone guide me where is the problem?
Video
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Color range : Full
Video
Format : HEVC
Codec ID : hvc1
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Color range : Full
Dolby provides binaries: https://github.com/DolbyLaboratories/dl ... master/binBetaExorcist wrote: ↑Tue Oct 26, 2021 7:17 amI looked at the guide on avsforum but I am having a little trouble with the installing from the Dolby labs GitHub do you think you could explain the installation process or know of some clear documentation or video that can help? I got as far as devenv mp4muxer_2010.sln /Rebuild but I got 2 errors one of which is a fatal one and I am not even sure I am doing it right in the first place.
I have a question regarding encoding a file to 1920x1080p and add the Dolby Vision later. Somehow, I don't get the right file after RPU insertion.
I have encoded a Game of Thrones Episode (4K REMUX, which is Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU). I encoded it without cropping, (which I do for every encode, also movies, I just resize it from 3840x2160 to 1920x1080).
It got me an 1080p episode, which is HDR10. I used the following command to change the .mkv file to hevc:
ffmpeg -y -i GOT.S01E01.mkv -an -c:v copy -f hevc GOT.S01E01.hevc
After this, I use the command to extract the RPU from the HEVC with mode 2:
dovi_tool -m 2 extract-rpu GOT.S01E01.hevc, which gives me an RPU.bin, which, I think should be converted to profile 8.
After this, I use the ffmpeg command to change the re-encoded file from .mkv file to hevc.file. I then usethe following command to inject the RPU into the re-encoded HEVC.file:
dovi_tool inject-rpu -i GOT.S01E01.HDR.hevc --rpu-in RPU.bin -o injected_output.hevc
But somehow, I doesn't work for me. It keeps begin SMPTE 2086, HDR10. Dolby Vision won't be visible in the hevc output file. When I mux the hevc.file to .mkv, then it still is only HDR10, and not Dolby Vision.
What is the part where I screw up? I'm doing it somewhere, but I just can't put my finger on it. Or is it a cropping thing? Some help with this would be very appreciated!
Regards,
Tormented12
Regards,
Tormented12
