4K BluRay
iismithii
4K BluRay
Post by iismithii »
Howdy y'all,
I hope you're well. I obtained a 4k BluRay of the Green Knight that I'm attempting to rip, with no luck. Got some curious errors stating that "LibreDrive compatible drive is required to open this disc - video can't be decrypted."
Attempted troubleshooting:
I've got the Enable Internet Access box checked
Just downloaded the latest version of MakeMKV
Restarted computer (Windows 10)
Waited for Windows to recognize disk before launching MakeMKV
I've included some logs below. Any help would be appreciated~
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KL4K59F1631
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: THE_GREEN_KNIGHT
Timestamp: 2021-08-19 19:54:27
Data capacity: 80.7 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at %7Yu*/.O+aNQ?1'djn:29396552
DEBUG: Code 4 at %7Yu*/.O+aNQ?1'djn:29394275
Saved AACS dump file as H:/Sights/Movies/MKB20_v76_The_Green_Knight_CBD6.tgz
DEBUG: Code 0 at {5RBA^y-#)9OM3ec:29396092
DEBUG: Code 0 at {5RBA^y-#)9OM3ec:29395172
Re: 4K BluRay
Is this the first 4K movie you've tried to rip?
MakeMKV requires a LibreDrive compatible optical drive to rip UHDs. You seem to have an optical drive that can be made LibreDrive compatible. You'll need to get the right firmware on the drive to make it work.
What is LibreDrive? viewtopic.php?f=19&t=18856
Flashing Guide: viewtopic.php?f=16&t=19634
