quietvoid
#5641 Post by quietvoid » Sat Oct 23, 2021 12:13 pm
powdeau wrote: Sat Oct 23, 2021 11:08 am When I convert HDR10+ do DoVi, do I need to change something in generator_example.json or can I leave it as it is?
You should adjust the JSON. Probably removing the level2 list as well as specifying proper level6 metadata.
mattmarsden
#5642 Post by mattmarsden » Sat Oct 23, 2021 5:46 pm
quietvoid wrote: Fri Oct 22, 2021 4:16 pm
mattmarsden wrote: Fri Oct 22, 2021 4:00 pmLooks like what I need - can you tell me how I use the script though? I've installed python but I'm not sure how to use it.
You need to demux the video first, and then run the script on the HEVC file.
example: python hdr10plus_remove.py -i video.hevc -o processed_file.hevc
Thanks for that. Is there an idiots guide on HDR10+ to DV conversion?
staknhalo
#5643 Post by staknhalo » Sat Oct 23, 2021 6:24 pm
mattmarsden wrote: Sat Oct 23, 2021 5:46 pm
I wrote up how this idiot does it here:
https://www.avsforum.com/threads/author ... t-60952335
Turn HDR10+ metadata into Dolby Vision metadata**
Command 1: 'hdr10plus_tool extract Video.hevc -o Metadata.json' (Extracts HDR10+ metadata and saves to .json file)
>>Next commands go through Dovi_Tool and v0.5.0 minimum required<<<
Command 2: 'dovi_tool generate -j Extra.json --hdr10plus-json Metadata.json --rpu-out RPUPlus.bin' (combines metadata from edited 'Extra.json' - template is below and you need to do one for every title specifically - and metadata from extracted 'Metadata.json' and combines+converts them into p8 RPU metadata format)
Command 3: 'dovi_tool.exe inject-rpu --input Video.hevc --rpu-in RPUPlus.bin' (Injects HDR10+ generated RPU metadata into HEVC stream turning it into single layer Dolby Vision 8 stream)
Blank Template for 'Extra.json'
"length": (title specific framelength here without parenthesis),
"level2": [
"target_nits": 100
"target_nits": 600
"target_nits": 1000
"target_nits": 2000
"level6": {
"max_display_mastering_luminance": (title specific metadata info here without parenthesis),
"min_display_mastering_luminance": (title specific metadata info here without parenthesis),
"max_content_light_level": (title specific metadata info here without parenthesis),
"max_frame_average_light_level": (title specific metadata info here without parenthesis)
#5644 Post by RESET_9999 » Sat Oct 23, 2021 6:26 pm
mattmarsden wrote: Sat Oct 23, 2021 5:46 pm Thanks for that. Is there an idiots guide on HDR10+ to DV conversion?
1- extract HDR10+ into a json
hdr10plus_parser.exe -i X:\HDR10+.hevc -o X:\HDR10+.json
2- create a json with L6 metadata (static HDR metadata: match your source)
    "length": 0,
    "level6": {
        "min_display_mastering_luminance": 50,
        "max_content_light_level": 0,
        "max_frame_average_light_level": 0
3- generate DV metadata
dovi_tool.exe generate --hdr10plus-json X:\HDR10+.json --json X:\L6.json --rpu-out X:\DVrpu.bin
4- inject DV metadata
dovi_tool.exe inject-rpu -i X:\HDR10+.hevc --rpu-in X:\DVrpu.bin
https://github.com/quietvoid/dovi_tool
https://github.com/quietvoid/hdr10plus_tool
mattmarsden
#5645 Post by mattmarsden » Sat Oct 23, 2021 6:37 pm
RESET_9999 wrote: Sat Oct 23, 2021 6:26 pm
hdr10plus_parser.exe -i X:\HDR10+.hevc -o X:\HDR10+.JSON
2- create a json with L6 metadata (static HDR metadata)
    "length": 0,
    "level6": {
dovi_tool.exe generate --hdr10plus-json X:\HDR10+.JSON --json X:\L6.json --rpu-out X:\DVrpu.bin
dovi_tool.exe inject-rpu -i X:\HDR10.hevc --rpu-in X:\DVrpu.bin
Brilliant, could you give me a link to the current dovi_tool.exe? Thanks very much
#5646 Post by RESET_9999 » Sat Oct 23, 2021 6:38 pm
mattmarsden
#5647 Post by mattmarsden » Sat Oct 23, 2021 6:52 pm
Sorry to be an absolute pain, could you also point me to the HDR10plus_parser.exe. Thanks!!
#5648 Post by RESET_9999 » Sat Oct 23, 2021 6:54 pm
mattmarsden
#5649 Post by mattmarsden » Sat Oct 23, 2021 7:00 pm
Amazing help, thanks so much. In a couple of days I'm going to be asking you about injecting the MADVR created metadata as DV!!
mattmarsden
#5650 Post by mattmarsden » Sun Oct 24, 2021 7:33 am
    "length": 0,
    "level6": {
Do you know how I can enter a "min_display_mastering_luminance" vlaue of 0.005? It doesn't seem to like that - it only want whole numbers. I've used 0 which I think must be close enough!
#5651 Post by RESET_9999 » Sun Oct 24, 2021 1:10 pm
mattmarsden wrote: Sun Oct 24, 2021 7:33 am
my json example is 0.0050
mattmarsden
#5652 Post by mattmarsden » Sun Oct 24, 2021 1:12 pm
RESET_9999 wrote: Sun Oct 24, 2021 1:10 pm
Ah OK - it says 50, am I reading it wrong?
quietvoid
#5653 Post by quietvoid » Sun Oct 24, 2021 1:13 pm
The value in the RPU should be multiplied by 10 000*, for the min.
So the common values: 0.0001 = 1, 0.0050 = 50, etc.
mattmarsden
#5654 Post by mattmarsden » Sun Oct 24, 2021 1:28 pm
quietvoid wrote: Sun Oct 24, 2021 1:13 pm The value in the RPU should be multiplied by 1000, for the min.
OK got you, but for the max leave it as it says.
mattmarsden
#5655 Post by mattmarsden » Mon Oct 25, 2021 2:14 pm
Sorry to keep going on about this but 0.0050 x 1000 = 5 - is 50 definitely correct for the value?
