Windows 11 ready - TPM Enabled - Hash Check Error
DudeItsRob
#1 Post by DudeItsRob » Wed Jun 30, 2021 12:49 am
Hey everybody, long time lurker here. I just wanted to give everybody a heads up, as this may save some headache for others. Recently Windows 11 was announced and of course like many others, I downloaded the tool to see if I can run Windows 11. I enabled TPM in bios, and I was Windows 11 ready - yay, right? Well, if you can see where this is going then no - not yay. A few days later I started ripping some blu-rays to be greeted by "Hash check error, file corrupted" among numerous hash check errors for EVERY-SINGLE DISK I tried.
Of course by now I'm angry, I tried my other optical drive (this PC has two) - same problem. Other PC would rip them without issue, so at this point I know it isn't the disk - so I replaced my optical drive with another one I had laying around and still nope. I thought there's no way I can have three bad optical drives... and finally I remembered enabling TPM in bios. Disabled it, and problems were gone.
I hope that there will be a work around before Windows 11 is released with a future MakeMkv update. I won't be upgrading to Windows 11 until I know that MakeMkv is compatible.
tldr: Makemkv is not compatible with TPM enabled in bios [At least not with Auros X570 Master 1.2 motherboard].
EDIT: The above was just a fluke. The issue came back and I discovered that I had a bad RAM module. The RAM only reported two errors during MemTest86's "Hammer Test" but after replacing the RAM the issue is gone.
ZU476B72N4PC
Re: Windows 11 ready - TPM Enabled - Hash Check Error
#2 Post by ZU476B72N4PC » Mon Jul 05, 2021 5:40 pm
That is very bizarre, not sure what's going on there. Presence of a TPM by itself should not affect the operation of MakeMKV. By any chance did you enable BitLocker after turning on the TPM? Perhaps temporary files during ripping are failing a hash check either before or after encryption of that file.
I have used MakeMKV on systems with both hardware TPM and Intel PTT without problems. (Though I haven't tried with AMD fTPM like your board has. Have you tried latest BIOS F33 with AGESA 1.2.0.2?)
DudeItsRob
#3 Post by DudeItsRob » Thu Jul 08, 2021 8:01 pm
I don't use BitLocker and don't have it enabled, and I can confirm that I was running the current BIOS F33. I suppose it is possible some sort of temporary file could have caused the error but I haven't tried to recreate the problem since. Deactivating fTPM seemed to get everything back to normal.
kristek
#4 Post by kristek » Sat Oct 23, 2021 12:32 am
This is still an issue, any updates?
babypuncher
#5 Post by babypuncher » Fri Nov 12, 2021 12:48 am
I don't think this is an issue specific to TPM or Windows 11. I upgraded to Windows 11 a few weeks ago and have had no issues ripping standard or 4K blu ray disks with makemkv.
I've also run with TPM 2.0 and BitLocker enabled for years.
DudeItsRob
#6 Post by DudeItsRob » Fri Apr 08, 2022 3:46 pm
kristek wrote: Sat Oct 23, 2021 12:32 am This is still an issue, any updates?
Sorry for the late response. Turned out I had bad RAM.
