agneva
Post by agneva » Thu Oct 21, 2021 12:42 pm
Hello, I haven't been here for a long time... but is there now a player that can play mkv with DolbyVision Duallayer (native EL) ?
My LG TV + Bluray Player can only play mp4 with AC3 Audio.
Poker354
Post by Poker354 » Fri Oct 22, 2021 4:47 am
A question for those with a Sony x700. I picked one up on sale about 3 weeks ago and just wondering if this glitch I'm experiencing is happening to everyone? When playing a dual track .ts Dolby Vision file via USB, if i stop the film and select another DV film its like it tries to play the two tracks independently one on top of the other and the screen is scrambled. Powering off and on fixes the issue for the next selected film but reappears again if i attempt another.
mattmarsden
Post by mattmarsden » Fri Oct 22, 2021 6:32 am
powdeau wrote:
Thu Oct 21, 2021 12:27 pm
galarond wrote:
Wed Oct 20, 2021 7:20 pm
powdeau wrote:
Wed Oct 20, 2021 4:32 pm
I've tried and unfortunately it doesn't.
weird, profile 8 m2ts files worked in my lg b6
Maybe it's because of the HDR10+
EDIT: I've tried to remove HDR10+ but it's not working either.
Can I ask how you remove HDR10+ because I need to do that on some files.
PlatypusW
Post by PlatypusW » Fri Oct 22, 2021 2:56 pm
See:
https://www.makemkv.com/forum/viewtopic ... 50#p104659
Then grab the file from RESET_9999’s signature :)
quietvoid
Post by quietvoid » Fri Oct 22, 2021 3:09 pm
You can try this: https://gist.github.com/quietvoid/175d7 ... 9eb1bd2c38
It's based on yusesope's script.
mattmarsden
Post by mattmarsden » Fri Oct 22, 2021 4:00 pm
Looks like what I need - can you tell me how I use the script though? I've installed python but I'm not sure how to use it.
quietvoid
Post by quietvoid » Fri Oct 22, 2021 4:16 pm
You need to demux the video first, and then run the script on the HEVC file.
example: python hdr10plus_remove.py -i video.hevc -o processed_file.hevc
powdeau
Post by powdeau » Sat Oct 23, 2021 11:08 am
When I convert HDR10+ do DoVi, do I need to change something in generator_example.json or can I leave it as it is?
quietvoid
Post by quietvoid » Sat Oct 23, 2021 12:13 pm
You should adjust the JSON. Probably removing the level2 list as well as specifying proper level6 metadata.
mattmarsden
Post by mattmarsden » Sat Oct 23, 2021 5:46 pm
Thanks for that. Is there an idiots guide on HDR10+ to DV conversion?
staknhalo
Post by staknhalo » Sat Oct 23, 2021 6:24 pm
I wrote up how this idiot does it here:
https://www.avsforum.com/threads/author ... t-60952335
Turn HDR10+ metadata into Dolby Vision metadata**
Command 1: 'hdr10plus_tool extract Video.hevc -o Metadata.json' (Extracts HDR10+ metadata and saves to .json file)
>>Next commands go through Dovi_Tool and v0.5.0 minimum required<<<
Command 2: 'dovi_tool generate -j Extra.json --hdr10plus-json Metadata.json --rpu-out RPUPlus.bin' (combines metadata from edited 'Extra.json' - template is below and you need to do one for every title specifically - and metadata from extracted 'Metadata.json' and combines+converts them into p8 RPU metadata format)
Command 3: 'dovi_tool.exe inject-rpu --input Video.hevc --rpu-in RPUPlus.bin' (Injects HDR10+ generated RPU metadata into HEVC stream turning it into single layer Dolby Vision 8 stream)
Blank Template for 'Extra.json'
"length": (title specific framelength here without parenthesis),
"level2": [
"target_nits": 100
"target_nits": 600
"target_nits": 1000
"target_nits": 2000
"level6": {
"max_display_mastering_luminance": (title specific metadata info here without parenthesis),
"min_display_mastering_luminance": (title specific metadata info here without parenthesis),
"max_content_light_level": (title specific metadata info here without parenthesis),
"max_frame_average_light_level": (title specific metadata info here without parenthesis)
Post by RESET_9999 » Sat Oct 23, 2021 6:26 pm
1- extract HDR10+ into a json
hdr10plus_parser.exe -i X:\HDR10+.hevc -o X:\HDR10+.json
2- create a json with L6 metadata (static HDR metadata: match your source)
    "length": 0,
    "level6": {
        "min_display_mastering_luminance": 50,
        "max_content_light_level": 0,
        "max_frame_average_light_level": 0
3- generate DV metadata
dovi_tool.exe generate --hdr10plus-json X:\HDR10+.json --json X:\L6.json --rpu-out X:\DVrpu.bin
4- inject DV metadata
dovi_tool.exe inject-rpu -i X:\HDR10+.hevc --rpu-in X:\DVrpu.bin
https://github.com/quietvoid/dovi_tool
https://github.com/quietvoid/hdr10plus_tool
mattmarsden
Post by mattmarsden » Sat Oct 23, 2021 6:37 pm
hdr10plus_parser.exe -i X:\HDR10+.hevc -o X:\HDR10+.JSON
2- create a json with L6 metadata (static HDR metadata)
    "length": 0,
    "level6": {
dovi_tool.exe generate --hdr10plus-json X:\HDR10+.JSON --json X:\L6.json --rpu-out X:\DVrpu.bin
dovi_tool.exe inject-rpu -i X:\HDR10.hevc --rpu-in X:\DVrpu.bin
Brilliant, could you give me a link to the current dovi_tool.exe? Thanks very much
Post by RESET_9999 » Sat Oct 23, 2021 6:38 pm
mattmarsden
Post by mattmarsden » Sat Oct 23, 2021 6:52 pm
Sorry to be an absolute pain, could you also point me to the HDR10plus_parser.exe. Thanks!!
