Hello.
I just received my slim external Archgon 4K Blu-Ray player.
Product: BD-RE BU40N
Revision: 1.01
Serial number: MO7KCTE5004
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Highest AACS version: 68
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Which firmware should I use to re-flash?
Many many thanks!
-sacolton
Which firmware to flash?
Re: Which firmware to flash?
Have you looked at the UHD Drives Flashing Guide? viewtopic.php?f=16&t=19634
i stand corrected
no no no please dont give wrong advice if they flash a BU40N to a WH16NS60 its probably permanently bricked they would need to do dos flash recovery
they should just reference my guide linked below it has what firmware to flash to for most drives
Please don't listen to the wrong advise that has been provided. The recommended firmware for your Archgon is DE_LG_BU40N_1.00. I should know, I've sold a lot of these units.sacolton wrote: Mon Feb 22, 2021 8:25 am Hello.
Revision: 1.01
Many many thanks!
-sacolton
grandpixel
I guess I will use this DE_LG_BU40N_1.00.bin file that I found in the DE firmware pack. (I'm assuming DE doesn't mean German language.) Billycar's guide that everyone links says to use 1.03MK on the BU40N, and then he's got a link to "the all you need firmware pack" which contains a file called "HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin".MartyMcNuts wrote: Mon Sep 20, 2021 5:32 am The recommended firmware for your Archgon is DE_LG_BU40N_1.00.
Can you just confirm which is really the best version, and why the discrepancy? Thanks.
the reason i have that as the recommended is 1.03mk will work in 1 step no matter what firmware your dive currently has.grandpixel wrote: Thu Oct 21, 2021 9:29 pm
1.00 de if you have 1.03 or higher is at least a 2 steps to get to 1.00de and in the future it may be more.
it just makes things simpler and less chance of flashing the wrong firmware.
BU40N 1.00 is still the best firmware for your drive. It is also compatbile with a much wider range of software compared to the MK versions, so the way I see it is this:grandpixel wrote: Thu Oct 21, 2021 9:29 pmI guess I will use this DE_LG_BU40N_1.00.bin file that I found in the DE firmware pack. (I'm assuming DE doesn't mean German language.) Billycar's guide that everyone links says to use 1.03MK on the BU40N, and then he's got a link to "the all you need firmware pack" which contains a file called "HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin".MartyMcNuts wrote: Mon Sep 20, 2021 5:32 am The recommended firmware for your Archgon is DE_LG_BU40N_1.00.
1. If you have a BU40N that comes with a firmware version less than 1.03, flash BU40N 1.00 and be done with it.
2. If you have a B40N that comes with firmware 1.03 or above:
- Flash 1.03-MK and leave it if you only use MakeMKV to rip your discs.
- If you use other ripping software, such as DVDFab, then flash your drive again to BU40N 1.00 as this firmware is compatible with other ripping software.
grandpixel
Okay, thank you both for the explanation. My Archgon came with 1.01 and I just went with 1.00, figured that would be a good starting point. Thanks for the confirmation.
