m2ts to mkv and AVCHD to mkv for sony camcorders
japr99
#1 Post by japr99 » Thu Jul 16, 2009 8:32 am
It's possible add to MakeMKV m2ts to mkv and AVCHD to mkv for sony camcorders ?, thanks.
Re: m2ts to mkv and AVCHD to mkv for sony camcorders
#2 Post by mike admin » Fri Jul 17, 2009 3:14 am
AVCHD should just work. What happens if open "index.bdmv" from file menu?
japr99
#3 Post by japr99 » Fri Jul 17, 2009 5:31 am
makemkv recognizes the format of iso fails but also fails to open the file index.bdmv-
DvdMark
#4 Post by DvdMark » Tue Jul 21, 2009 9:19 pm
I have the same problem. I use a blu ray iso. Whatever i do everytime when the output size is 105 mb it fails.
What is causing this problem?
I use makemkv for mac.
#5 Post by mike admin » Thu Jul 23, 2009 6:59 am
The error shows that problem is with subtitles, so as a workaround you may try to uncheck all subtitles. We're still trying to figure out exact cause though.
