Crash on loading The Legend of Hell House Bluray / Scream Factory
bill_w
Post by bill_w »
When first reading the disc, MakeMKV crashes with the generic error message "Fatal error occurred, program will now exit." It is a brand new disc and looks perfectly clean with no blemishes. Any ideas would be appreciated. I am hoping to have this ripped by Halloween. Unfortunately, I don't have a Bluray player, so I can't check the disc. I only watch them ripped.
Debug log:
Debug log started at Mon Oct 18 19:48:19 2021 , written by MakeMKV v1.16.4 linux(x64-release)
001005:0000 MakeMKV v1.16.4 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/bill/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.68.0/OpenSSL/1.1.1f/1.40.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at :dF09'kc`L+X+;OGG >t^*:29393631
No  SDF v07e: ASUS_DRW-24B1ST___j_1.01_H3D0CL019869
SDF id v07e: ASUS_DRW-24B1ST___j_1.01_H3D0CL019869
SDF  v07e: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLFL25A2346
001011:0000 Using LibreDrive mode (v06.2 id=7FC45AF98B4B)
DEBUG: Code 2147483648 at <_zSP&06Pi+Hb)S):121264625
Found java version=11.0.11 path=/usr/lib/jvm/java-11-openjdk-amd64/bin/java
Found java version=11.0.11 path=/usr/bin/java
003344:0000 Using Java runtime from /usr/lib/jvm/java-11-openjdk-amd64/bin/java
001003:0020 DEBUG: Code 0 at *4Flj}2p)WGo.`7(-o:213130007
001003:0020 DEBUG: Code 1 at q~C)PvoxE\_(Tljc~:213131548
Screen cap:
Re: Crash on loading The Legend of Hell House Bluray / Scream Factory
I wander if Java crashed while trying to interpret the disc? What happens if you don't let MakeMKV use Java on the disc?
bill_w
Post by bill_w »
Sure enough, I renamed java and it ripped fine. Strange that hasn't happened with any other disc. Thanks!
