FubbAyH
Post by FubbAyH »
This is interesting stuff!
staknhalo wrote:
Thu Oct 14, 2021 3:35 pm
it appears to be DV player led playback entirely within the given app (display won't kick into DV mode, the RPU is processed and video output altered by the given Win Store video-playback app itself)
So would it be fair to say that it's basically automatically converting/downgrading the DV source to SDR/HDR10?
Post by Manixx2020beyound »
FubbAyH wrote:
Thu Oct 14, 2021 3:50 pm
It’s sdr as far as I know.
But better sdr than mad vr from what I’m told.
staknhalo
Post by staknhalo »
Manixx2020beyound wrote:
Thu Oct 14, 2021 3:53 pm
It puts out HDR brightness/levels (by eye not measurement) when the DV file has an HDR10 base (P8) on my end if that's what you mean? HDR has to be on beforehand on Windows for HDR media/gaming though - even with a TV instead of monitor - it doesn't kick into HDR for you like TVs/TV devices do
that is old news.... the dolby extension will allow DV P5 playback for certified DV PC and will fallback in HDR10 or SDR for the non-certified pc..
I tested it a while ago, both the HDR10 and SDR tonemapping sucks.
Also, you need the HEVC extension which isn't free anymore ( thanks Micro$oft)
staknhalo
Post by staknhalo »
RESET_9999 wrote:
Thu Oct 14, 2021 4:07 pm
But on profile 8 files as confirmed with that test file it's processing and displaying the changes in the DV RPU metadata when playing back - so it's not just 'HDR/SDR only' output on non-certified (mine) PCs, it's the dynamic DV metadata output/DV playback as well for uncertified PCs
staknhalo wrote:
Thu Oct 14, 2021 4:12 pm
wait what ? you are triggering DV from a non-certified DV PC ?
staknhalo
Post by staknhalo »
RESET_9999 wrote:
Thu Oct 14, 2021 4:17 pm
yes my pc is all self built not store bought and not DV certified at all - my PC monitor is HDR10 only not DV (my TV though is)
with that dolby vision windows plugin installed rpu changes in dv8 files which that test file demonstrates - display correctly on my computer/computer monitor and playback with the RPU changes applied/displayed/apparent when watching - uninstall the DV plugin and the video plays back without any changes being apparent even though the text in the test video indicates you should be seeing visual changes
profile 5 files also play back in correct colors for me only when that plugin is installed, in HDR brightness levels (again by eye not measurement) and I'm assuming RPU metadata too like p8 but no p5 file to test for RPU that like as with the p8 test file
staknhalo wrote:
Thu Oct 14, 2021 4:22 pm
yes my pc is self built not store built and not DV certified at all - my PC monitor is HDR10 only not DV (my TV though is)
with that dolby windows plugin installed rpu changes in dv8 files which that test file demonstrates - display correctly on my computer and playback with the RPU changes applied/displayed/apparent - uninstall the DV plugin and the video plays back without any changes being apparent even though the text in the test video indicates you should be seeing changes
I build my PC myself too, not sure what this has to do with this?
You haven't answered my question... Does it trigger DV on your DV TV ?
probably not, so it tonemap DV to HDR10 (or SDR). That's my whole point, the DV to HDR10 (or SDR) tonemapping from the dv extension sucks big time.
staknhalo
Post by staknhalo »
RESET_9999 wrote:
Thu Oct 14, 2021 4:27 pm
I said it does not trigger DV on the TV when hooked right up to the TV it stays in HDR10 - but the RPU dynamic metadata is still displayed and applied (very apparently) all the same on playback when that plugin is installed - and does not when it isn't - that shouldn't be happening if it was only HDR10/SDR playback - so it is playing back/displaying the DV metadata on my uncertified computer, not just only the underlying base video - that's what I was trying to highlight
staknhalo wrote:
Thu Oct 14, 2021 4:30 pm
I said it does not trigger DV on the TV when hooked right up to the TV it stays in HDR10 - but the RPU dynamic metadata is still displayed and applied (very apparently) all the same on playback when that plugin is installed - and does not when it isn't - that shouldn't be happening if it was only HDR10/SDR playback - so it is playing back the DV metadata on my uncertified computer not just the underlying base video
yeah, we already knew that when the extension was first available months ago.
I said that the DV to HDR10 (or SDR) tonemapping is off (regardless of the DV metadata).... My x700 (newer firestick TV too) can do exactly the same but the tonemapping is right (well except for the raised black levels)
plus the Windows player doesn't support lossless audio anyway and has incorrect static metadata.
FubbAyH
Post by FubbAyH »
It is interpreting the RPU, as you say, but I do still think it's more accurate to describe this as a "DV to SDR/HDR10 conversion". I don't think it's the same as player-led DV. My understanding is that with player-led DV the TV sends parameters about itself to the player (e.g. its brightness capabilities) and the player feeds that into the magic DV algorithms along with the RPU to produce an output signal specifically tuned for that TV.
With this Windows playback, it's not receiving any parameters from the TV/monitor so it must just be interpreting the RPU in a generic way. Perhaps that's useful, but we should be clear that it's not really the full DV experience.
powdeau
Post by powdeau »
Hi, is it somehow possible to convert profile 8 to profile 5?
I have a file with dvhe.08.06, BL+RPU (and also with HDR10+, which I dont need) and I want to play it on my LG C7.
Thank you very much!
quietvoid
Post by quietvoid »
powdeau wrote:
Wed Oct 20, 2021 11:28 am
No. Are you sure your TV doesn't support profile 8?
It works on the C8 with ts files.
powdeau
Post by powdeau »
quietvoid wrote:
Wed Oct 20, 2021 1:26 pm
I've tried and unfortunately it doesn't.
powdeau
Post by powdeau »
galarond wrote:
Wed Oct 20, 2021 7:20 pm
powdeau wrote:
Wed Oct 20, 2021 4:32 pm
weird, profile 8 m2ts files worked in my lg b6
Maybe it's because of the HDR10+
EDIT: I've tried to remove HDR10+ but it's not working either.
