Fedora Linux converting to AAC fails - no library
stevenfalco
Post by stevenfalco »
I am trying to rip the main title from The Wizard of Oz 75th Anniversary BD, while converting audio to AAC using the AAC-stereo profile.
I get the error "LIBMKV_TRACE: encoder 'libfdk_aac' not found in ffmpeg/libavcodec library"
On my system, I apparently have two libfdk_aac libraries:
/usr/lib64/libfdk-aac.so.2.0.0
/usr/lib64/fdk-aac/libfdk-aac.so.2.0.2
I noticed that the error message has an underscore (libfdk_aac) while the library has a dash (libfdk-aac). Is that why it is not found? And if so, how would I correct it? Or is it a problem with ffmpeg?
BTW, this title has DTS-HD MA Surround 5.1 audio.
This is my first posting on this forum - if more info is needed please let me know what to provide.
Re: Fedora Linux converting to AAC fails - no library
You have to compile libfdk separately; it has licensing that allows source-only distribution.
stevenfalco
Thanks - I'll give that a try.
