compulov
Re: SDFtool Flasher
Post by compulov » Sun Oct 10, 2021 5:58 pm
Not sure if anyone had tried this yet, but I just wanted to mention it works fine in Windows 11... the *ARM* release of Windows 11, running in a virtual machine on an M1 Mac. I gave it a go because I didn't feel like digging up my Windows laptop. The only workaround I needed to implement was to change the HighDPI scaling method, otherwise the app window was all messed up.
Re: SDFtool Flasher
Post by MartyMcNuts » Sun Oct 10, 2021 9:51 pm
compulov wrote: Sun Oct 10, 2021 5:58 pm Not sure if anyone had tried this yet, but I just wanted to mention it works fine in Windows 11... the *ARM* release of Windows 11, running in a virtual machine on an M1 Mac. I gave it a go because I didn't feel like digging up my Windows laptop. The only workaround I needed to implement was to change the HighDPI scaling method, otherwise the app window was all messed up.
Good to know!
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Oct 14, 2021 3:40 am
I have been advised that Buffalo BN13 is an encrypted firmware, so this has been added to the encrypted firmware list. SDFtool Flasher has been updated to v1.2.3 to include this firmware. Download link has been updated in the original post of this thread.
zeeegerman
Re: SDFtool Flasher
Post by zeeegerman » Sat Oct 30, 2021 4:23 am
Marty, brilliant work here! If we were in person, I'd "bro hug" you. :mrgreen:
The flasher tool worked like a charm. No brainer. WH16NS60 w/Vantec enclosure, flashed in about 30 seconds. Fired up MakeMKV, now Ripping Ford Vs. Ferrari.
Golf clap, air Five, etc...Thanks a lot!
Let me know if you're taking donations for your efforts (seriously).
zeeegerman
zeeegerman
***HT Specs: Yamaha Aventage RX-A70: Dolby ATMOS 7.2.2: Def Tech FL/FR: BP9020 (w/ATMOS A90), C: CS9040, (2) Super Cube 4000, Mythos XTR-20BP (SL/R; SBL/R); VAVA 4K UST, OPTOMA ALR101E, AppleTV 4K, Sony 4K Bluray ***
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Oct 30, 2021 5:58 am
Hi zeeegerman,
Glad you are all sorted. Enjoy ripping your movie collection!!
mm8718
Re: SDFtool Flasher
Post by mm8718 » Sat Nov 06, 2021 11:56 am
@MartyMcNuts
I need some help
I am getting pretty consistent failed rips with my hardware but not always.
In the last week i just tried ripping Jungle cruise UHD and THOR Dark World UHD and they are both failing. I tried MakeMKV and DVD Fab UHD Rip with the same issues. Contrary to that an older UHD copy of Se7en worked fine.
DVD Fab has a tool to adjust the firmware and it seems to suggest the 1.02 is needed whereas i have 1.05 which works some times!
Can someone help? I would rather not pay the extortionate fee for DVD fab Drive tool!
Here's my drive details:
Product: BD-RE BH16NS40
Revision: 1.05
Serial number: KL7KAT81109
Firmware date: 2120-05-06 13:31
Highest AACS version: 76
Firmware version: 1.05
And here is what the SDF write sees:
SDF Drive Details
SDF Drive Details
SDF Write.PNG (10.48 KiB) Viewed 21372 times
Re: SDFtool Flasher
Post by Coopervid » Sat Nov 06, 2021 12:26 pm
Look on page 1 of this thread and download the DE firmware pack. It contains 1.02.
viewtopic.php?f=16&t=22896
revengineer
Re: SDFtool Flasher
Post by revengineer » Sat Nov 06, 2021 1:22 pm
Marty,
the GUI is hosed on my 4k monitor. The text does not fully show and I am unable to move or resize the GUI.
Thank you for your software, it has served me well in the past.
Cheers.
Re: SDFtool Flasher
Post by Coopervid » Sat Nov 06, 2021 8:51 pm
Just reduce the resolution for the time being.
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Nov 06, 2021 10:01 pm
revengineer wrote: Sat Nov 06, 2021 1:22 pm 2021-11-06.pngMarty,
Cheers.
Can you please try adjusting the DPI settings of the SDFtool flasher exe file as per below.
DPI Settings.jpg (100.58 KiB) Viewed 21341 times
Let me know if this helps.
revengineer
Re: SDFtool Flasher
Post by revengineer » Sun Nov 07, 2021 12:36 pm
MartyMcNuts wrote: Sat Nov 06, 2021 10:01 pm Can you please try adjusting the DPI settings of the SDFtool flasher exe file as per below.
I confirm that this works. Thank you so much!
cloudyapple
Archgon drive
Post by cloudyapple » Tue Nov 16, 2021 12:56 pm
Have the below Archgon drive purchased from Amazon.
Loaded up the GUI flasher and the MK firmwares.
I heard this is the same as the LG BU40N, but there are many choices for this.
Which version should I choose?
Do I have an encrypted firmware currently and need to check some box?
Screenshot 2021-11-16 204110.png (16.84 KiB) Viewed 21171 times
Product: BD-RE BU40N
Revision: 1.01
Serial number: MO2L3VA5517
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Re: Archgon drive
Post by MartyMcNuts » Tue Nov 16, 2021 9:20 pm
cloudyapple wrote: Tue Nov 16, 2021 12:56 pm Have the below Archgon drive purchased from Amazon.
Revision: 1.01
As you can see, the SDFtool Flasher tells you that the drive does not have encrypted firmware (the red X beside "Encrypted firmware"). Just flash DE_LG_BU40N_1.00 firmware and be done with it. Start ripping your UHD discs.
cloudyapple
Re: SDFtool Flasher
Post by cloudyapple » Tue Nov 16, 2021 10:52 pm
Thanks a lot Marty, look like it is done!
What a great tool!
Revision: 1.00
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
It does however looks like VLC doesn't play a UHD disc.
Am I right it is meant to be a ripping drive, not really a directly playable drive, i.e. no way to directly play it correct?
screenshot_VLC error.png (9.97 KiB) Viewed 21140 times
Mr_Orange
Re: SDFtool Flasher
Post by Mr_Orange » Wed Nov 17, 2021 2:06 am
The firmware enables ripping.
You can set up VLC integration from the Preferences in MakeMKV.
