And what about the Fire TV Cube (2019)? The Amlogic S922 SoC is able to decoding FEL.quietvoid wrote: ↑Fri Oct 08, 2021 1:12 amThe credits are grey like HDR10, so nothing new.RESET_9999 wrote: ↑Fri Oct 08, 2021 12:23 amthat's because I did those samples with tsmuxer and it breaks something in the RPU when you split the file. I didn't know about that back then.
As @FubbAyH said, the ending credits of Power Ranger is a better way to verify if FEL is processed.
@quietvoid
Thanks for your Great work on Dovi.
Have you compiled an update Kodi version for the Firestick 4k (original not the Max)?
I am using the version available in Fandango's Matrix 19 Final
Guys, question.
I'm re-encoding some of my UHD Remuxes. I wanto to inject then RPU into re-encoded BL.
This way I can easily create MKV files with Dolby Vision Profile 8. Playing flawlessly on my Shield 2019 Pro.
But what if I wanted to create a file that I could play directly on different TVs? I just used mp4muxer to create DoVi Profile 8 mp4. However it plays well on my Shield but not on my LG OLED B9. (which I did not expcted as this TV is able to play MP4 Profile 7)
So what container and DoVi Profile should I choose if I want to create a file being able to be playd directly on TVs? At leat on LG OLED we are using in our family?
MP4? TS? M2TS? What profile?
I want this file to be able to be played on TV, Shield and Android mobile devices. If there is no DoVi compatibility then it would be good if the file is played as HDR. That's why I think the only format BL+RPU with HDR compatibility is Profile 8?
Maybe I can mux them into Profile 7 with some "fake" EL layer?
Profile 7 MP4s play fine on my LG OLED and Android mobile devices.
Thx for help.
Thx for help.
I build my own but it's running Kodi 20 Nexus, and doesn't include all binary addons.
You can find it here: https://mega.nz/file/4BVTTAoI#KBpPwfQZ1 ... cjlh62Bh-s
The code branch is this https://github.com/quietvoid/xbmc/tree/ ... oska_build
I think Maven's builds might be better for you though, from here: https://www.kodinerds.net/index.php/Thr ... ür-Android
Both are probably a different package name.
I downloaded your Nexus version but have problems for sideloading in the Firestick. Have you any suggestion?
Not sure I can help you with that.
I always install mine through ADB, like this:
adb install -r kodi-20-Nexus-dovi-armeabi-v7a-release-2021-10-07.apkRe: Dolby Vision now possible through MP4 Mux.
Ok. So I tried
mp4muxer --overwrite --dv-profile 5
and the file reporst as
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
MP4 works perfectly on LG OLED and Shield 2019 Pro.
If I turn off DoVi in my Shield the file plays as HDR. I though Profile 8 is not HDR compatible? Anyway. This is exactly what I wanted.
Question 1:
What other TVs/sticks will I be albe to play this file on as Dolby Vision? Fire Stick 4K? Sony TV?
Question 2:
Is there any mobile device (Android, iOS) capable of displaying mp4 DoVi Profile 5 as Dolby Vision?
Thanks @quietvoid
Please can you give a more detailed step by step guide on how to use it?
Sorry for my ignorance, I never heard of adb and dont know what to do.
Thanks.
Thanks.
The basics of it are to get the tools from here: https://developer.android.com/studio/re ... form-tools
You then need to enable the ADB debugging on the device, it's in the developer options.
Then you can connect with adb by command line with adb connect IP:port.
And then you should be able to install the app.
There are many tutorials on the usage of ADB.
Thanks for the new build!quietvoid wrote: ↑Sun Oct 10, 2021 1:52 pmI build my own but it's running Kodi 20 Nexus, and doesn't include all binary addons.
(Although Kodi is unusable for me on Firestick4k (ethernet cable, not wifi) for whatever reason: low read rate ... message, and it just stalls for a long time...)
I just upgraded his build with adbLink easily, just installing the new apk again.
@chros
Many thanks it was easy as you said.
quietvoid wrote: ↑Sat Oct 09, 2021 3:45 pmAnyways, it made me create a cropped test sample for the important metadata: https://mega.nz/file/8YsRRKJa#_g_vX2voc ... raveYPpiIA
Indeed, really nice, thanks! Now we could see L2 metadata in action!
RESET_9999 wrote: ↑Sat Oct 09, 2021 3:54 pminteresting thanks... will try on my x700.
that sample has very small black bars though
Tried it on Oppo, and yes, grey bars are there.RESET_9999 wrote: ↑Sat Oct 09, 2021 3:54 pmhaha, trust me you will.
Having this exact problem with my x700, I just can't stand the grey black bars(especially the 1600px content). I even prefer my Shield with the red push for p8 cropped content(no red push with p5).
The interesting part is that how grey it is depends on the metadata! E.g. from the previously linked Dolby manual (thanks for thjis for you RESET and Mannix):
"... Blu-ray players ... Due to this implementation on these devices, any positive lift applied to Dolby Vision content during the “trim pass,” will raise the black levels in the letterbox/blanking areas of the image and can become distracting to the end user. Dolby recommends a maximum positive lift value of 0.025 while doing the trims on letterboxed content during the Dolby Vision content creation process."
Thanks, now that's interesting. Maybe we can ask mashdi to provide this value as well in the measurement file.
What do you think what would happen if it's not 0 during tonemapping? I mean what's the effect of this value?
Does anyone compared the result this type of metadata RPU (from madvr) vs static metadata RPU (1 for all frames), if so is there any difference?
Reset, Mannix?
Min pq is mostly set to 0 on hdr10plus, & produces the same result on hdr10 plus to dv rpu.chros wrote: ↑Mon Oct 11, 2021 9:15 amquietvoid wrote: ↑Sat Oct 09, 2021 3:45 pmAnyways, it made me create a cropped test sample for the important metadata: https://mega.nz/file/8YsRRKJa#_g_vX2voc ... raveYPpiIAIndeed, really nice, thanks! Now we could see L2 metadata in action!
that sample has very small black bars thoughTried it on Oppo, and yes, grey bars are there.RESET_9999 wrote: ↑Sat Oct 09, 2021 3:54 pmhaha, trust me you will.
Reset, Mannix?
There should definitely be a difference per frame vs 1 for all frames.
But on true min pq value dv dynamic meta it varies more often
If mad vr handles scenes changes the same way as dv, the dynamic meta produced should be very close I would assume.
Last edited by Manixx2020beyound on Mon Oct 11, 2021 3:28 pm, edited 1 time in total.
This is not the same problem, the lift affects letterbox bars that are already present in the content.chros wrote: ↑Mon Oct 11, 2021 9:15 amThe interesting part is that how grey it is depends on the metadata! E.g. from the previously linked Dolby manual (thanks for thjis for you RESET and Mannix):
But in our case there are grey bars when the content does not have letterbox bars at all, because they were cropped out.
