How I Met Your Mother - Season 7
BardHawk
#1 Post by BardHawk » Sun Oct 10, 2021 2:43 am
Went through all 9 seasons on DVD but season 7 Make MKV can't see the files. Each season is 3 discs. When I open the discs in explorer all the files are there, and I can watch them normally on the DVDs, but even the most up-to-date version of Make MKV doesn't see the files on any of the 3 discs. I assume this is some kind of copyright protection Make MKV isn't overriding, but it's weird it's only this one particular season (which would be 2012) when the next two newer seasons (8 & 9) aren't a problem. Anyone have any ideas how I can get Make MKV to see these so I can copy them?
Re: How I Met Your Mother - Season 7
#2 Post by Woodstock » Sun Oct 10, 2021 2:45 am
Are you seeing any errors in the log (assuming you have debug logging enabled)?
BardHawk
#3 Post by BardHawk » Sun Oct 10, 2021 3:11 am
Debugging is enabled and there are no errors. There are debug codes and title skips and then the log ends with "Operation Successfully Completed".
BardHawk
#4 Post by BardHawk » Thu Oct 28, 2021 12:59 am
No one has a clue apparently what the problem would be, so guessing it's just that Make MKV was fooled by the right protection.
#5 Post by dcoke22 » Thu Oct 28, 2021 3:03 am
Maybe post your log into this thread? I don't have that TV show so I haven't experienced your issue directly but maybe there's something in the log.
kennova
#6 Post by kennova » Sun Dec 26, 2021 6:48 pm
Interestingly I'm seeing the same thing with Season 5. I've tried 4 different drives on 3 different computers. So I don't think it's hardware.
In the end I turned on expert mode, and it could see the tracks and I could request the appropriate titles. That may work for you as well.
These are the helpful pages.
http://makemkv.com/manualdvd/
viewtopic.php?t=15370
kennova
#7 Post by kennova » Sun Dec 26, 2021 7:16 pm
Got to Season 7. Had the same issue you did. Manual mode worked though.
