mamelem
#5581 Post by mamelem » Sat Oct 09, 2021 1:52 pm
TickTock wrote: Sat Oct 09, 2021 1:44 pm
mamelem wrote: Sat Oct 09, 2021 7:13 am Ok, I tried this route and now x800m2 can successfully switch to DV.
However, after pressing “Display”, it shows that the output resolution is only 1080p and not 4K (even though x800m2 list the source as 4K DV). When testing the original UHD, x800m2 can successfully output 4K.
I’m confused on what went wrong. From my understanding, since UHD DV are dual layers, I included the 1080p layer when remuxing into a new m2ts when using tsmuxeR.
What version of tsmuxer are you using? At one stage only nightly versions worked, I don't know if that has changed but here's the version I've been using:
https://easyupload.io/vsxlud
Have you tried playing the newly created files off a drive?
You're right, both layers should be left as is.
Connected x800m2 directly to TV instead of receiver fixed the issue. Guess it’s a bandwidth issue? Interesting that remuxed m2ts apparently takes up more bandwidth than UHD.
TickTock
#5582 Post by TickTock » Sat Oct 09, 2021 2:59 pm
mamelem wrote: Sat Oct 09, 2021 1:52 pm
Do you have a "4K Signal Format" setting on your AVR? If so, is it set to "Enhanced"?
mamelem
#5583 Post by mamelem » Sat Oct 09, 2021 3:07 pm
TickTock wrote: Sat Oct 09, 2021 2:59 pm
Oh wow, that’s it. Thanks!
These AV hardware keeps surprising me with important settings buried in menus lol.
#5584 Post by RESET_9999 » Sat Oct 09, 2021 3:16 pm
quietvoid wrote: Sat Oct 09, 2021 1:23 pm
I don't know since I'm not subscribed to ATV+ currently. Disney+ does not crop their video.
What's interesting though is that Hulu serves both HDR10+ and DoVi together and there were no complaints.
wow, so they removed the ability to play properly DV cropped content on the new Firestick, that is a really stupid move since everything on iTunes or Prime is cropped.
The last time I checked , HULU content is not cropped as well. (they have ridiculously low bitrate though )
quietvoid
#5585 Post by quietvoid » Sat Oct 09, 2021 3:45 pm
RESET_9999 wrote: Sat Oct 09, 2021 3:16 pmwow, so they removed the ability to play properly DV cropped content on the new Firestick, that is a really stupid move since everything on iTunes or Prime is cropped.
Yeah, I'm not sure if I'll bother switching to the 2018 model though. I only noticed the grey bars with fades to black.
Anyways, it made me create a cropped test sample for the important metadata: https://mega.nz/file/8YsRRKJa#_g_vX2voc ... raveYPpiIA
With this everything seems to work fine otherwise.
credits to FF.de for the original HDR10+ test sample, from which I used the different L1 metadata.
#5586 Post by RESET_9999 » Sat Oct 09, 2021 3:54 pm
quietvoid wrote: Sat Oct 09, 2021 3:45 pm Yeah, I'm not sure if I'll bother switching to the 2018 model though. I only noticed the grey bars with fades to black.
haha, trust me you will.
Having this exact problem with my x700, I just can't stand the grey black bars(especially the 1600px content). I even prefer my Shield with the red push for p8 cropped content(no red push with p5).
quietvoid wrote: Sat Oct 09, 2021 3:45 pm Anyways, it made me create a cropped test sample for the important metadata: https://mega.nz/file/8YsRRKJa#_g_vX2voc ... raveYPpiIA
interesting thanks... will try on my x700.
that sample has very small black bars though
FubbAyH
#5587 Post by FubbAyH » Sat Oct 09, 2021 6:13 pm
That's a great sample @quietvoid. It's very interesting to see examples of all the DV adjustments, because until now I've always been a little bit vague about exactly what the DV metadata can do.
NiCE77
#5588 Post by NiCE77 » Sun Oct 10, 2021 11:10 am
quietvoid wrote: Fri Oct 08, 2021 1:12 am
FubbAyH wrote: Fri Oct 08, 2021 12:16 am Would you be able to try one of the titles where the FEL is obvious (e.g. Power Rangers or Total Recall) to see if it is being used?
RESET_9999 wrote: Fri Oct 08, 2021 12:23 amthat's because I did those samples with tsmuxer and it breaks something in the RPU when you split the file. I didn't know about that back then.
As @FubbAyH said, the ending credits of Power Ranger is a better way to verify if FEL is processed.
The credits are grey like HDR10, so nothing new.
And what about the Fire TV Cube (2019)? The Amlogic S922 SoC is able to decoding FEL.
quietvoid
#5589 Post by quietvoid » Sun Oct 10, 2021 1:28 pm
NiCE77 wrote: Sun Oct 10, 2021 11:10 amAnd what about the Fire TV Cube (2019)? The Amlogic S922 SoC is able to decoding FEL.
I don't know, I don't own a FireTV Cube.
ragico
#5590 Post by ragico » Sun Oct 10, 2021 1:39 pm
@quietvoid
Thanks for your Great work on Dovi.
Have you compiled an update Kodi version for the Firestick 4k (original not the Max)?
I am using the version available in Fandango's Matrix 19 Final
juzer7
#5591 Post by juzer7 » Sun Oct 10, 2021 1:48 pm
Guys, question.
I'm re-encoding some of my UHD Remuxes. I wanto to inject then RPU into re-encoded BL.
This way I can easily create MKV files with Dolby Vision Profile 8. Playing flawlessly on my Shield 2019 Pro.
But what if I wanted to create a file that I could play directly on different TVs? I just used mp4muxer to create DoVi Profile 8 mp4. However it plays well on my Shield but not on my LG OLED B9. (which I did not expcted as this TV is able to play MP4 Profile 7)
So what container and DoVi Profile should I choose if I want to create a file being able to be playd directly on TVs? At leat on LG OLED we are using in our family?
MP4? TS? M2TS? What profile?
I want this file to be able to be played on TV, Shield and Android mobile devices. If there is no DoVi compatibility then it would be good if the file is played as HDR. That's why I think the only format BL+RPU with HDR compatibility is Profile 8?
Maybe I can mux them into Profile 7 with some "fake" EL layer? :lol: Profile 7 MP4s play fine on my LG OLED and Android mobile devices.
Thx for help.
quietvoid
#5592 Post by quietvoid » Sun Oct 10, 2021 1:52 pm
ragico wrote: Sun Oct 10, 2021 1:39 pm Have you compiled an update Kodi version for the Firestick 4k (original not the Max)?
I build my own but it's running Kodi 20 Nexus, and doesn't include all binary addons.
You can find it here: https://mega.nz/file/4BVTTAoI#KBpPwfQZ1 ... cjlh62Bh-s
The code branch is this https://github.com/quietvoid/xbmc/tree/ ... oska_build
I think Maven's builds might be better for you though, from here: https://www.kodinerds.net/index.php/Thr ... ür-Android
Both are probably a different package name.
ragico
#5593 Post by ragico » Sun Oct 10, 2021 1:57 pm
I downloaded your Nexus version but have problems for sideloading in the Firestick. Have you any suggestion?
quietvoid
#5594 Post by quietvoid » Sun Oct 10, 2021 1:59 pm
ragico wrote: Sun Oct 10, 2021 1:57 pm Thanks
Not sure I can help you with that.
I always install mine through ADB, like this:
adb install -r kodi-20-Nexus-dovi-armeabi-v7a-release-2021-10-07.apk
The -r flag is to overwrite an existing install, I think.
juzer7
#5595 Post by juzer7 » Sun Oct 10, 2021 2:17 pm
juzer7 wrote: Sun Oct 10, 2021 1:48 pm
Ok. So I tried
mp4muxer --overwrite --dv-profile 5
and the file reporst as
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
MP4 works perfectly on LG OLED and Shield 2019 Pro.
If I turn off DoVi in my Shield the file plays as HDR. I though Profile 8 is not HDR compatible? Anyway. This is exactly what I wanted.
Question 1:
What other TVs/sticks will I be albe to play this file on as Dolby Vision? Fire Stick 4K? Sony TV?
Question 2:
Is there any mobile device (Android, iOS) capable of displaying mp4 DoVi Profile 5 as Dolby Vision?
