Dear community,
I've a big issue with makemkv.
It's not albe to find any usable optical drives (screenshot at the bottom of the page), but Windows and all other applications do.
It's not allowed to change "Administrative Templates" because my version of Windows is Pro not Home.
PLEASE DO YOU HAVE ANY SOLUTION?????
It's driving me crazy.
many many thanks
bennacer
makemkv can't find any usable optical drives -Windows 10 Pro-
bennacer
Re: makemkv can't find any usable optical drives -Windows 10 Pro-
Windows 10 does not, by default, allow low-level access to REMOVABLE MEDIA, as part of the "anti ransomware protection", unless the software has been signed by Microsoft as "safe". MakeMKV is not signed by Microsoft; You need to add an exception for it.
Rather than point you at a potentially fishy site that explains how to do this, I suggest a search for "windows ransomware exception" and picking one of the Microsoft tech articles on it.
bennacer
thanks for your answer.
unfortunately my "anti ransomware protection" is disabled so there isn't any exception to allow......
Just for grins, have you tried running MakeMKV w/ elevated privileges (Run as Administrator)? IF that works, there's an option, unchecked by default during installation, which may help w/ that situation.bennacer wrote: Sat Oct 09, 2021 1:27 pm thanks for your answer.
bennacer
no way- neither with the option checked nor with the option unchecked ............................d00zah wrote: Sat Oct 09, 2021 8:28 pmJust for grins, have you tried running MakeMKV w/ elevated privileges (Run as Administrator)? IF that works, there's an option, unchecked by default during installation, which may help w/ that situation.bennacer wrote: Sat Oct 09, 2021 1:27 pm thanks for your answer.
In addition to the ransomware settings, Windows 10 Pro can have group policy restrictions on using optical drives. Some kick in when you are using remote access software (Gotomypc, Windows Remote Access, similar), and some that deal with local access by non-admin users. You can even disable access by ALL users to the command channels of a drive. And Windows Defender can impose restrictions.
Personally, I've only had to deal with the remote user permissions. Those were simple to avoid by not using remote access until I corrected them. They were also rather obvious that things would work UNTIL you weren't on-site.
Is this a machine that has any remote admin functions set up, or are you the machine admin?
bennacer
Dear Woodstock,Woodstock wrote: Sun Oct 10, 2021 1:09 am In addition to the ransomware settings, Windows 10 Pro can have group policy restrictions on using optical drives. Some kick in when you are using remote access software (Gotomypc, Windows Remote Access, similar), and some that deal with local access by non-admin users. You can even disable access by ALL users to the command channels of a drive. And Windows Defender can impose restrictions.
many thanks for your help and constancy.
to be honest I think that there isn't any user permission or restriction that it's not allowed, especially related to optical drive.
I'm the admin of lapton and I assume this position because the optical drive works with all the other programs (VLC etc etc)
I guess the issue is related toe MakeMKV itself .....
