Any tools to scan a directory of MKVs?
boe_d
Post by boe_d »
I'd like to know which of my mkv's have subtitles without manually opening each to find out.
Re: Any tools to scan a directory of MKVs?
I assume you mean that you don't PERSONALLY have to open each one...
There are tools like MediaInfo which can generate text files with information about various media files. You could also use parts of the mkvtoolnix suite to scan them.
boe_d
Post by boe_d »
Thanks for the reply. I ended up going with a file explorer add on - Icaros.
