Second copy of same Blu-ray hangs during ripping
Niggi Biggi
#1 Post by Niggi Biggi » Thu Sep 30, 2021 11:11 pm
I’ve been trying to rip a Blu-ray disc several times, but it always fails on the exact same spot.
This is strange to me, because the disc I have been trying to rip most recently is the second copy of the same exact Blu-ray edition, which I bought in the hopes that it was simply a faulty disc giving me trouble.
Unfortunately for me, it seems to be more complicated than that, and as such I have provided logs for you to read.
Hopefully, it will be of some help:
On the “first” attempt, I ejected the disc since it took forever to finish, but like I said, it fails on the exact same spot as the original copy:
MakeMKV v1.16.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\User/MakeMKV_log.txt
Using LibreDrive mode (v06.2 id=EC0D0F39EDA7)
Title #00017.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.mpls has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.mpls (angle 1) was added as title #0
File 00000.mpls (angle 2) was added as title #1
Title #00025.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00007.mpls was added as title #2
Title #00026.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 233 at g/PBF1bP86DTHbv5NHlOgNU8:0
DEBUG: Code 233 at Qf+e+T8otjLhDfSNTj0KJ37X:0
DEBUG: Code 233 at 6JPtMU1kpTXWZrAG6XIr1aX3:0
Saving 2 titles into directory C:/Users/User/Videos/Blu-ray rips
Error 'OS error - {No Disk} There is no disk in the drive. Please insert a disk into drive hs' occurred while reading '\Device\CdRom0' at offset '5680404480'
DEBUG: Code 3221225491 at s;K)vw02vHn&n=S*-I:29395149
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '5680404480'
DEBUG: Code 100809218 at s;K)vw02vHn&n=S*-I:29395149
DEBUG: Code 0 at 3^I}\]5zSt1@'wRY|:h4:29395471
DEBUG: Code 0 at E-SUWZ;L!g{q.+K5H;9D:29394068
DEBUG: Code 0 at 3^I}\]5zSt1@'wRY|:h4:213131157
DEBUG: Code 0 at 3^I}\]5zSt1@'wRY|:h4:121262647
DEBUG: Code 2773635 at 3^I}\]5zSt1@'wRY|:h4:121261773
DEBUG: Code 0 at X2*S=quXQAT`[?@-MidaB:213129984
DEBUG: Code 0 at &laO~GKEY~}UeZMm)C%fM:213137068
DEBUG: Code 48631 at 4j8sikbee]wQ/+$W:29399933
DEBUG: Code 0 at 4j8sikbee]wQ/+$W:213134492
DEBUG: Code 7 at 4j8sikbee]wQ/+$W:213132997
Error 'OS error - {No Disk} There is no disk in the drive. Please insert a disk into drive hs' occurred while reading '\Device\CdRom0' at offset '257273856'
DEBUG: Code 3221225491 at @po,<Mk*SbZVSCU\:29377945
DEBUG: Code 0 at d{}_}R^'g5]vZQX"E":29394183
AV sync issue in stream 3,6 at 1:28:05.504 with duration of 2123.328s : 66354 frame(s) dropped to reduce audio skew to +9.333ms
Failed to save title 0 to file C:/Users/User/Videos/Blu-ray rips/Flåklypa Grand Prix_t00.mkv
DEBUG: Code 0 at 8{`H&D"$jx2(r:YXP:29398691
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '0'
DEBUG: Code 0 at E-SUWZ;L!g{q.+K5H;9D:213133687
DEBUG: Code 0 at 3^I}\]5zSt1@'wRY|:h4:121262348
DEBUG: Code 0 at 3^I}\]5zSt1@'wRY|:h4:121262210
DEBUG: Code 0 at 3^I}\]5zSt1@'wRY|:h4:121261773
DEBUG: Code 0 at q6{x+qDJ3<27hrOvO/]d:213136769
DEBUG: Code 0 at 4j8sikbee]wQ/+$W:213130858
DEBUG: Code 0 at &laO~GKEY~}UeZMm)C%fM:29400462
DEBUG: Code 0 at 4j8sikbee]wQ/+$W:213130582
DEBUG: Code 0 at d{}_}R^'g5]vZQX"E":121269708
DEBUG: Code 0 at d{}_}R^'g5]vZQX"E":121270007
Failed to save title 2 to file C:/Users/User/Videos/Blu-ray rips/Flåklypa Grand Prix_t02.mkv
0 titles saved, 2 failed
This is from the second attempt, where I pressed the “STOP” button:
Saving 1 titles into directory C:/Users/User/Videos/Blu-ray rips
DEBUG: Code 0 at @po,<Mk*SbZVSCU\:29397610
Error 'Internal error - Operation was cancelled (135)' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '250134528'
DEBUG: Code 122136 at 3^I}\]5zSt1@'wRY|:h4:121261773
DEBUG: Code 0 at Kd[>;5U_yyp-2TA~:q>D:29394022
DEBUG: Code 0 at Kd[>;5U_yyp-2TA~:q>D:29404878
DEBUG: Code 0 at Kd[>;5U_yyp-2TA~:q>D:29405384
DEBUG: Code 0 at Kd[>;5U_yyp-2TA~:q>D:29403383
DEBUG: Code 0 at 4j8sikbee]wQ/+$W:213132537
DEBUG: Code 0 at VAeOa8Lkh/?1\V<Hn:121264464
DEBUG: Code 0 at VAeOa8Lkh/?1\V<Hn:121263912
DEBUG: Code 0 at VAeOa8Lkh/?1\V<Hn:213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
DEBUG: Code 117506183 at @po,<Mk*SbZVSCU\:29377945
0 titles saved, 1 failed
I’ve tried cleaning the disc, obviously replacing it, and I’ve increased the “read retry count” as well.
I haven’t tried I different drive, but it seems incredibly unlikely to me that it’s got anything to do with my drive at this point.
Re: Second copy of same Blu-ray hangs during ripping
#2 Post by dcoke22 » Fri Oct 01, 2021 2:20 am
How is the drive connected to your computer? And how is it powered? Sometimes USB powered drives can attempt to do things that make the drive need more power than a single USB port can provide, which leads to all kinds of weird behavior.
Messages like that qualify as weird behavior. :)
ham6817
#3 Post by ham6817 » Fri Oct 01, 2021 3:04 am
name of the movie would probably help
Niggi Biggi
#4 Post by Niggi Biggi » Fri Oct 01, 2021 6:36 am
dcoke22 wrote: Fri Oct 01, 2021 2:20 am How is the drive connected to your computer? And how is it powered? Sometimes USB powered drives can attempt to do things that make the drive need more power than a single USB port can provide, which leads to all kinds of weird behavior.
It is an internal drive - LG BH16NS55 to be specific.
Like I said, I ejected the disc in this instance because it took forever to rip.
Niggi Biggi
#5 Post by Niggi Biggi » Fri Oct 01, 2021 6:37 am
ham6817 wrote: Fri Oct 01, 2021 3:04 am name of the movie would probably help
The name of the movie is "Flåklypa Grand Prix":
https://www.blu-ray.com/movies/Flaklypa ... ray/89386/
ham6817
#6 Post by ham6817 » Sun Oct 03, 2021 7:38 am
Niggi Biggi wrote: Fri Oct 01, 2021 6:37 am
Have you tried ripping if with a different program.
#7 Post by dcoke22 » Sun Oct 03, 2021 2:47 pm
When rip gets into the state where it is taking a long time, can you tell which file it seems to be having trouble with? During a rip the top of the MakeMKV window has an 'Information' box with a lot of details in it.
Here's an example I've obfuscated a bit.
The "Source file" line near the top will tell you which .m2ts file MakeMKV is currently working on ripping. The "Output size" is an effective proxy for how well the rip is going. If the growth of the output size slows down, or seems to come to a stop, the "Source file" line will tell you which .m2ts file is giving your optical drive trouble.
There is a difference between when things just slow down and when things seem to get stuck. In my experience, if the output size is increasing, even slowly, there's still a chance that the rip will eventually finish. If things seem to stall, then often I'll end up with a hash check error or some other related error.
I mention all this because your earlier log indicated you were attempting to save two titles. It is possible the file giving the drive trouble is only part of one of those titles and the other title might successfully rip. Before starting the rip, if you highlight a title in MakeMKV and then look at the "Segment map" line in the Info box on the right, you can see if there's a segment that corresponds to the file that the rip seems to be stalling out on.
For example, 00501.m2ts (for the picture above) corresponds to segment 501 from the picture below.
I know this won't solve the issue, but it might help get us closer.
#8 Post by dcoke22 » Sun Oct 03, 2021 2:57 pm
Niggi Biggi wrote: Thu Sep 30, 2021 11:11 pm I haven’t tried I different drive, but it seems incredibly unlikely to me that it’s got anything to do with my drive at this point.
I have multiple, different optical drives I use to rip. It has been my experience that some discs just don't work well in some drives. Generally speaking, I rip everything in my 'main' drive, which is just the one I use first out of habit. If a rip fails, I next try the disc in my other drive. More often than not, the rip is successful in the other drive. If it isn't, I clean the disc and try again. On very rare occasions, I come across a disc that won't work in any of the three drives I have access to even after multiple cleanings. This is when I replace the disc. So far, in all those cases, of which I've only had a handful over the years (though I had one last week), the replacement copy has worked.
It seems like you've done everything except try a different drive. A different drive or perhaps an alternative program (as ham6817 suggests) might be the remaining things to try. Personally, I don't have any experience with any ripping programs besides MakeMKV, so I can't make a suggestion there.
Niggi Biggi
#9 Post by Niggi Biggi » Wed Oct 06, 2021 10:05 pm
dcoke22 wrote: Sun Oct 03, 2021 2:47 pm When rip gets into the state where it is taking a long time, can you tell which file it seems to be having trouble with? During a rip the top of the MakeMKV window has an 'Information' box with a lot of details in it.
Here's some information from another unsuccessful rip:
First, I took a screenshot of the "information box".
Secondly, a picture of the point where the rip runs into problems. It sounded like the drive was constantly seeking.
At this point, the drive ceased to seek, the estimated remaining time kept adding up, and I decided to stop the ripping process by clicking the "STOP" button.
Lastly, here's the log from before I manually stopped the ripping process.
Evaluation version, 24 day(s) out of 30 remaining
DEBUG: Code 233 at j6GLEBXHH8BV4QfEo/tymppm:0
Any idea as to what could be causing this?
Niggi Biggi
#10 Post by Niggi Biggi » Wed Oct 06, 2021 10:11 pm
ham6817 wrote: Sun Oct 03, 2021 7:38 am
Which program would you recommend?
I'd like it if there was a free alternative to MakeMKV, but so far, the alternatives seem to want to make you purchase the software.
Come to think of it, I really wish MakeMKV was FOSS, since it's such a great piece of software most of the time.
ham6817
#11 Post by ham6817 » Fri Oct 08, 2021 4:18 am
Niggi Biggi wrote: Wed Oct 06, 2021 10:11 pm
I also have DVDFab but i have always used MakeMKV with no problem. Also what is FOSS
Niggi Biggi
#12 Post by Niggi Biggi » Fri Oct 08, 2021 5:23 pm
ham6817 wrote: Fri Oct 08, 2021 4:18 am
FOSS stands for "free and open-source software", which is software that is freely available for anyone to edit, modify and reuse.
hagenman
#13 Post by hagenman » Fri Jan 21, 2022 6:12 pm
Has anyone had any further progress on this? I have the same disc with the exact same problem, I'm stumped as well.
mbaservdk
#14 Post by mbaservdk » Wed Mar 15, 2023 7:16 pm
+1
squash1621
#15 Post by squash1621 » Sat Jan 13, 2024 5:14 pm
Same problem for me on flåklypa
backing up unencrypted works just fine and i can wiev the 00015.m2ts manualy in vlc, but cant make a mkv file with makemkv
MakeMKV v1.17.5 win(x64-release) started
The program can't find any usable optical drives.
Opening files on harddrive at //mathias-nas/makemkv/backup/FLAKLYPA GRAND PRIX
Title #00016.mpls has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00017.mpls has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00024.mpls has length of 66 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00025.mpls has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00026.mpls has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00006.m2ts has length of 28 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00007.m2ts has length of 13 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00008.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00017.m2ts has length of 0 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00019.m2ts has length of 66 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00020.m2ts has length of 30 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00021.m2ts has length of 71 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00024.m2ts has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00027.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00028.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00030.m2ts has length of 10 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00032.m2ts has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00033.m2ts has length of 9 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00034.m2ts has length of 71 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 100 seconds and was therefore skipped
Saving 1 titles into directory //mathias-nas/makemkv/Flåklypa Grand Prix
Error 'OS error - Det oppstod en uventet nettverksfeil' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '5492643840'
Error 'OS error - Det oppstod en uventet nettverksfeil' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '257273856'
Failed to save title 0 to file //mathias-nas/makemkv/Flåklypa Grand Prix/Flåklypa Grand Prix_t00.mkv
