I just extracted Guardians of the Galaxy 1 (4K) from disc. It went smoothly with no errors, the output was a 56gb mkv.
The video through HDMI to my Sony X900E is washed out which is a well known HDR problem. But what I found odd were the video attributes when I opened it. Instead of 3840 x 2160 the direct rip shows as 1920x1080 at only 23 fps. Any idea why MakeMKV would alter these?
Guardians of the Galaxy 1 in 4K - resolution errors
thewallace
Re: Guardians of the Galaxy 1 in 4K - resolution errors
Makemkv does not alter it.
Something else in your chain is probably doing live encoding.
What is your playback device and how is it streamed to there?
thewallace
I just opened the mkv in Magix Vegas and it shows the same settings. I have the feeling that these settings are displaying incorrectly for some reason. I wonder if there's a way to change them at the file level without resaving it.
Noone seems to have discussed ripping the 1st episode of these movies. Maybe the encryption has a layer that's difficult to get off properly.
Mediainfo (https://mediaarea.net/en/MediaInfo) can tell you all kinds of details about your .mkv files. Point it at the file in question and see what it says.
If it's a Dolby vision title that software may be incorrectly showing the dv enchantment stream as the main info dv info would be 1080p
thewallace
Solved it, the file was corrupt somehow. I ripped it to a mkv a 2nd time and resolution is correct. Probably should have tried this it before.
