Clone 007 Blu-Ray help
Buhraxz1
#1 Post by Buhraxz1 » Wed Sep 29, 2021 11:12 pm
Hello. I have unsuccessfully tried to make a clone of a disc that I am missing in my James bond collection.
I have tried to make a backup from an original disk via MakeMKV.
MakeMKV makes a folder with "BDMV, Certificate, MakeMKV" and I tried to burn it again on a new Blu-ray disc with imgburn. This works however when it is to play in my player then it recognizes the disc as "The Living Daylights" but afterwards a red screen appears saying "Warning: Your Blu-ray player requires an update in order to play this disc. Please visit your Blu-ray player's manufacturers website and follow their instructions to update your Blu-ray player …. "
What should I try now, I have tried with ImgBurn to make an iso file and burn it to a disk. same result
Now I have wasted 2x 50Gb disks
Some suggestions? I want everything, menu, extras, etc.
I have tried both discs in my PS3 & PS4.
The original works fine :?:
-Frederik
Re: Clone 007 Blu-Ray help
#2 Post by Coopervid » Mon Oct 04, 2021 3:16 pm
Please omit that Makemkv folder and only make the ISO using the BDMV and Certificate folder. I have a Clone-OPPO player M9702 and the same effect happens if there is also a Makemkv folder in addition to the other two.
Buhraxz1
#3 Post by Buhraxz1 » Mon Oct 04, 2021 3:21 pm
Sorry
Can you try to simplify the steps I need to do I Oder to get it working :)
#4 Post by Coopervid » Mon Oct 04, 2021 5:02 pm
Makemkv creates these folders:
BDMV
Certificate
Makemkv
Just delete the "Makemkv" folder and use only BDMV and Certificate for your ISO or your disc to be burned.
Your and my player get confused when they see this non-standard "Makemkv" folder in addition to BDMV and Certificate.
Buhraxz1
#5 Post by Buhraxz1 » Mon Oct 04, 2021 6:03 pm
Thanks I'll try that :D
#6 Post by Coopervid » Mon Oct 04, 2021 9:33 pm
Please report back.
Buhraxz1
#7 Post by Buhraxz1 » Wed Dec 29, 2021 8:38 pm
sorry for no reply
i did not make it work sadly, so i dident try further
-Buhraxz1
