Wrong Sorting order?
DocBean
Post by DocBean »
So I started to backup my Orphan Black blu-ray discs (UK). As I rip episodes individually, I select them and unselect the main entry. After I ripped the first disc, I played what I thought the first episode, and discovered that it was actually the 3rd episode.
Sorting Order MKV.jpg (174.47 KiB) Viewed 4398 times
It seems that File 0000.mpls, which was added as title #3, is in fact the first episode. I loaded the same disc in DVDFab, and this is the listing:
Sorting Order DVD.jpg (68.83 KiB) Viewed 4398 times
According to that, 0 = episode 1, 2 = episode 3.
Is MakeMKV sorting it wrongly, or DVDFab?
thetoad
Re: Wrong Sorting order?
Post by thetoad »
sorting order says nothing. you have a play all playlist (29GB), just look at the 3 pieces that are probably listed in it and associate them to the piece listed for the other 3.
