What would it take for LibreDrive format for HL-DT-ST CH10LS20?
Millmaster
Post by Millmaster »
I have an LG HL-DT-ST BVDVDRW CH10SL20. I see all sorts of drives listed including L30, but not L20. Is there any magic to getting it added?
Re: What would it take for LibreDrive format for HL-DT-ST CH10LS20?
What does MakeMKV say about it?
If there is no LibreDrive section of the Info window under "Drive Information" when you start MakeMKV, there is no current or planned support for the drive (my UH08LS10 from 2009 is that way).
Panic54
Post by Panic54 »
Sorry Im totally new to ripping - if it did not occour already
It currently says:
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.00-00
I guess the driver platform is wrong?
Panic54 wrote:
Tue Sep 28, 2021 9:00 am
It currently says:
yeah wrong controller chip for now might be added later.
what are you trying to do with the drive
Panic54
Post by Panic54 »
currently I have a Family PLEX-server with DVD's and HD blurays. I have recently got a 4k oled and wanted to find out if it was time to upgrade/buy some 4k HDR material for that server, but I was unsure if my current BD drive was able to rip those
Panic54 wrote:
Tue Sep 28, 2021 10:01 am
that drive cant do 4k but if you want one that does see my guide of supported drives or buy one from me
Panic54
Post by Panic54 »
Billycar11 wrote:
Tue Sep 28, 2021 10:04 am
Hmm okay thanks then I will hold off the 4k's for now
and Thanks for the offer, but I will wait for a bit :)
It is probably worth pointing out that MakeMKV can utilize more than one optical drive at the same time. On the IO tab in MakeMKV's Preferences, if you turn on 'Ask for single drive mode' and if you have more than one optical drive on your system, when you start MakeMKV, it'll ask you which optical drive you want that instance of MakeMKV to use. There should also be a menu item called New MakeMKV instance, which can be pointed at a different optical drive. You can then rip more than one disc at the same time.
This is a long winded way of saying adding a UHD-friendly optical drive doesn't mean you have to stop using your existing drive. Buying a recommended drive from the list and flashing it yourself isn't super hard and buying a pre-flashed and tested drive from one of the sellers listed is even easier (and a bit more expensive for the obvious reasons).
ham6817
Post by ham6817 »
Purchase a drive from me that is UHD friendly, there pretty cheap
ham6817
Post by ham6817 »
Millmaster wrote:
Mon Jan 13, 2020 11:15 pm
Purchase the drive i have for sale and be done with it.
