F9 The Fast Saga
JulesKeeper
F9 The Fast Saga
I'm located in the US. I just received this 4K disc today. When I tried rip it, I received the following error message:
DEBUG: Code 0 at {5RBA^y-#)9OM3ec:29396092
DEBUG: Code 0 at {5RBA^y-#)9OM3ec:29395172
I just emailed the log file. Please let me know if you need anything else. Thanks for your help.
tcoble33
Re: F9 The Fast Saga
Same here. First time I've seen this "failed to open disc" error. Suggestions?
Fixing Volume Key is Unknowntcoble33 wrote: Tue Sep 21, 2021 1:07 am Same here. First time I've seen this "failed to open disc" error. Suggestions?
Just sent off my best buy steel book dump.
binhton@gmail.com
just sent the dump for Rebox disc.
JulesKeeper
It's been 2 days and I'm still unable to rip F9 4K UHD. I've emailed another dump .tgz file.JulesKeeper wrote: Mon Sep 20, 2021 11:11 pm I'm located in the US. I just received this 4K disc today. When I tried rip it, I received the following error message:
FYI...I've been able to rip 4K UHD "Black Widow" and "Cruella".
Thanks for the help.
binhton@gmail.com
I can decrypt the Redbox disc now.
JulesKeeper
Works now!!! Thank you!!!JulesKeeper wrote: Wed Sep 22, 2021 7:12 pmIt's been 2 days and I'm still unable to rip F9 4K UHD. I've emailed another dump .tgz file.JulesKeeper wrote: Mon Sep 20, 2021 11:11 pm I'm located in the US. I just received this 4K disc today. When I tried rip it, I received the following error message:
ham6817
do you guys have allow internet access checked
ionblue
I'm having the same problem. Tried to rip it on Tuesday, sent the dump file, and have been trying a few times a day since. I have internet access enabled and was able to rip the blu-ray versions just fine. Not so much on the UHD.
I've tried 2 different drives:
OS device name: /dev/rdisk14
Product: BD-RE BU40N
Revision: 1.03
Serial number: MZZJ3TE2507
Highest AACS version: 76
Firmware version: 1.03
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLUJ5MD3517
Bus encryption flags: 1F
Firmware version: 3.10
Any ideas on getting this thing to rip??
Also a note for folks having playback issues in Plex - it may be the extended version and something to do with the branch to grab the extra scenes. I say this cause I have the same problem with The Martian Extended edition ONLY. The regular one plays just fine. Someone over in Plex land posited that it may be something with the the extra bits are getting pulled in. It's way over my head.
Revision: 1.03
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Do you have a log you can post?ionblue wrote: Thu Sep 23, 2021 4:35 pm I'm having the same problem. Tried to rip it on Tuesday, sent the dump file, and have been trying a few times a day since. I have internet access enabled and was able to rip the blu-ray versions just fine. Not so much on the UHD.
ionblue
Sure thing. Not much here though. One from each drive just in case. Are there any other logs??
Also, I did check to make sure DNS wasn't acting hinky on me. It's fine. Or seems to be at any rate.
003332:0000 Saved AACS dump file as file:///file/system/place/MakeMKV/MKB20_v76_F9_D24C.tgz
003303:0000 The volume key is unknown for this disc - video can't be decryptedEven though others have posted that the disc is decrypting for them, it is sometimes the case that the same title has multiple encryption keys. This is a reason why it is helpful to post which key you submit. In your case, you've got key "D24C". Someone else very likely submitted a different key, which had a different file name.
ionblue
Already sent another one today. I’ll try not to keep being a pest about it. Didn’t realize there could be multiple keys.dcoke22 wrote: Fri Sep 24, 2021 12:15 amThat's pretty much it in a nutshell. Email that .tgz file to svq@makemkv.com.Code: Select all
003332:0000 Saved AACS dump file as file:///file/system/place/MakeMKV/MKB20_v76_F9_D24C.tgz 003303:0000 The volume key is unknown for this disc - video can't be decrypted
Even though others have posted that the disc is decrypting for them, it is sometimes the case that the same title has multiple encryption keys. This is a reason why it is helpful to post which key you submit. If your case, you've got key "D24C". Someone else very likely submitted a different key, which had a different file name.
Thanks much.
