Flashing Checksum Err BU40n
I've read a lot of threads and guides and still having issues. First post, sorry if in wrong place.
I started here https://www.swedetrap.com/how-to-rip-4k ... ray-discs/ and bought same drive. From posts on this board it seems to be a popular one. I am using Windows 10 and have it plugged in to a usb-c port.
New slim drive: Archgon Premium Aluminum External USB 3.0 UHD 4K Blu-Ray Writer Super Drive for PC and Mac
mkv reports:
OS device name: H:
Product: BD-RE BU40N
Revision: 1.01
Serial number: MO1L3VD2215
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Trying to flash with Downgrade Enabled Firmware V.2
I get:
Target HL-DT-STBD-RE BU40N 1.01
Current Version 1.01-01
New Version 1.00-A4
Hitting flash and it returns
CheckSum is mismatched.Drive will go to BOOT mode Please retry again
thanks for any help.
mkv reports:
OS device name: H:
Revision: 1.01
I get:
New Version 1.00-A4
Re: Flashing Checksum Err BU40n
From 1st post in Ultimate UHD Drives Flashing Guide Updated 2021
Recommended Firmware to flash for MakeMKV:
BU40N on any Firmware directly to > BU40N 1.03MK
has links to New! The all you need firmware pack & New! GUI SDF tool
I think I went down this path partially before and then stumbled.
I didn't find a direct match for: "BU40N 1.03MK"
I found two so far
1) HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin in the Mk-firmware-pack
2) HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 which is from the "All you need firmware pack"?
Do I use one of those?
Thanks for the help!
I found two so far
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 is 1.03MKmsadams wrote: ↑Thu Sep 23, 2021 2:16 amI think I went down this path partially before and then stumbled.
I found two so far
Thank-you that worked.
I was able to use MakeMKV now on an UHD disks. I also paid for the copy of MakeMKV.
Does anyone know if there is a ROM that is safe to flash to this drive to make it AnyDVD friendly as well?
No, there isn't one. Slim drives cannot be made "friendly" for AnyDVD usage.
Ok thanks! I can now rip mkv files for our NAS from our UHD disks so I am happy with that!
I really appreciate the help and the great software
I made a mistake.
I flash my BU40N Lg Drive directly to the 1.04 original firmware.
I need to flash it with the HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin firmware or with the HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin firmware.
I get the same message :
"ChekSum is mismatched.
Drive will go to boot mode
Please retry again."
I didn't manage to flash it with downgrade tool (Both with Friendly Firmware Pack and Downgrade Enabled Firmware V.2)
I didn't understand clearly if it is finally possible or not.
Can you please make me see the light ?
Cheers.
I made a mistake.
Cheers.
Use enc
What does "enc" mean ?
"enc" is for "encrypted", all right.
But what do I do ?
I have to use SDF tool ?
But what do I do ?
Allright,
I follow the tutorial under "How to flash[...] and commands", at viewtopic.php?f=16&t=19634#p74718, recommanded here.
I copied the firmware to the c: root, open cmd in "execute" (not Powershell) and write :
"cd C:\Program Files (x86)\MakeMKV
makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin"
where "E:" is MY path drive (be careful).
And it flashed !
Thank you very much, guys, and see you.
And it flashed !
Ive tried to flashing to both 1.00 and 1.03 and get the same error "Checksum is mismatched" is there an updated version of this tutorial? I cand find anything on youtube or online.Billycar11 wrote: ↑Thu Sep 23, 2021 2:34 amHL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 is 1.03MKmsadams wrote: ↑Thu Sep 23, 2021 2:16 amI think I went down this path partially before and then stumbled.
I found two so far
Are you perhaps starting from an encrypted FW & NOT using the 'enc' switch?
Paraphrased from above:
- Remove disc in optical drive, if any.
- Copy HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin to c:\
- Open 'Command Prompt" (not Powershell) and (assuming your drive letter is E:) execute:
makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Updated guide linked belowMattyB wrote: ↑Fri Jul 01, 2022 4:55 pmIve tried to flashing to both 1.00 and 1.03 and get the same error "Checksum is mismatched" is there an updated version of this tutorial? I cand find anything on youtube or online.Billycar11 wrote: ↑Thu Sep 23, 2021 2:34 amHL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 is 1.03MKmsadams wrote: ↑Thu Sep 23, 2021 2:16 amI think I went down this path partially before and then stumbled.
I found two so far
