MakeMKV v1.6.5 darwin(x86-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI mode.
Optical drive "HD-DVD-ROM HL-DT-ST BD-RE BE06LU10 YE05" opened in DASPI mode.
Evaluation version, evaluation period expired 9 day(s) ago
Automatic SVQ downloading is disabled or failed.
Loaded 14 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00002.svq
Saved BD+ dump file as /Volumes/media-1/Blu-Ray Movies/dump_The_A-Team_3A01E1251AE79C4F.tgz
BD+ code processed, got 1 FUT(s) for 57 clip(s)
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00381.mpls was added as title #0
Title #00020.mpls has length of 110 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
File 00800.mpls was added as title #3
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00301.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00303.m2ts has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00306.m2ts has length of 200 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00309.m2ts has length of 85 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00311.m2ts has length of 115 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00313.m2ts has length of 371 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00316.m2ts has length of 120 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00319.m2ts has length of 164 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00321.m2ts has length of 293 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00324.m2ts has length of 329 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00327.m2ts has length of 368 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00328.m2ts has length of 80 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00331.m2ts has length of 186 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00333.m2ts has length of 142 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00334.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00335.m2ts has length of 51 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00336.m2ts has length of 55 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00338.m2ts has length of 475 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00342.m2ts has length of 103 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00345.m2ts has length of 209 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00347.m2ts has length of 103 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00350.m2ts has length of 367 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00352.m2ts has length of 74 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00353.m2ts has length of 58 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00354.m2ts has length of 85 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00355.m2ts has length of 114 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00356.m2ts has length of 164 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00357.m2ts has length of 79 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00358.m2ts has length of 186 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00359.m2ts has length of 248 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00360.m2ts has length of 209 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00379.m2ts has length of 439 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00383.m2ts has length of 198 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00384.m2ts has length of 246 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00385.m2ts has length of 275 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00386.m2ts has length of 301 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00387.m2ts has length of 368 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00388.m2ts has length of 371 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00380.m2ts has length of 96 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00389.m2ts has length of 145 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00390.m2ts has length of 72 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00391.m2ts has length of 108 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00392.m2ts has length of 100 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00393.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00394.m2ts has length of 99 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00377.m2ts has length of 91 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00378.m2ts has length of 7 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00889.m2ts has length of 145 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00890.m2ts has length of 146 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00891.m2ts has length of 146 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00011.m2ts has length of 9 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/media-1/Blu-Ray Movies/The_A-Team
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '0'
Failed to save title 1 to file /Volumes/media-1/Blu-Ray Movies/The_A-Team/title01.mkv
0 titles saved, 1 failed
