F9 The Fast Saga
JulesKeeper
F9 The Fast Saga
Post by JulesKeeper »
I'm located in the US. I just received this 4K disc today. When I tried rip it, I received the following error message:
DEBUG: Code 0 at {5RBA^y-#)9OM3ec:29396092
DEBUG: Code 0 at {5RBA^y-#)9OM3ec:29395172
I just emailed the log file. Please let me know if you need anything else. Thanks for your help.
tcoble33
Re: F9 The Fast Saga
Post by tcoble33 »
Same here. First time I've seen this "failed to open disc" error. Suggestions?
Post by d00zah »
tcoble33 wrote: Tue Sep 21, 2021 1:07 am Same here. First time I've seen this "failed to open disc" error. Suggestions?
Fixing Volume Key is Unknown
Post by SamuriHL »
Just sent off my best buy steel book dump.
binhton@gmail.com
Post by binhton@gmail.com »
just sent the dump for Rebox disc.
JulesKeeper
JulesKeeper wrote: Mon Sep 20, 2021 11:11 pm I'm located in the US. I just received this 4K disc today. When I tried rip it, I received the following error message:
It's been 2 days and I'm still unable to rip F9 4K UHD. I've emailed another dump .tgz file.
FYI...I've been able to rip 4K UHD "Black Widow" and "Cruella".
Thanks for the help.
binhton@gmail.com
binhton@gmail.com wrote: Tue Sep 21, 2021 5:41 pm just sent the dump for Rebox disc.
I can decrypt the Redbox disc now.
JulesKeeper
JulesKeeper wrote: Wed Sep 22, 2021 7:12 pm
Works now!!! Thank you!!!
ham6817
Post by ham6817 »
do you guys have allow internet access checked
ionblue
Post by ionblue »
I'm having the same problem. Tried to rip it on Tuesday, sent the dump file, and have been trying a few times a day since. I have internet access enabled and was able to rip the blu-ray versions just fine. Not so much on the UHD.
I've tried 2 different drives:
OS device name: /dev/rdisk14
Product: BD-RE BU40N
Revision: 1.03
Serial number: MZZJ3TE2507
Highest AACS version: 76
Firmware version: 1.03
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLUJ5MD3517
Bus encryption flags: 1F
Firmware version: 3.10
Any ideas on getting this thing to rip??
Also a note for folks having playback issues in Plex - it may be the extended version and something to do with the branch to grab the extra scenes. I say this cause I have the same problem with The Martian Extended edition ONLY. The regular one plays just fine. Someone over in Plex land posited that it may be something with the the extra bits are getting pulled in. It's way over my head. :)
ionblue wrote: Thu Sep 23, 2021 4:35 pm I'm having the same problem. Tried to rip it on Tuesday, sent the dump file, and have been trying a few times a day since. I have internet access enabled and was able to rip the blu-ray versions just fine. Not so much on the UHD.
Do you have a log you can post?
ionblue
Post by ionblue »
dcoke22 wrote: Thu Sep 23, 2021 9:25 pm Do you have a log you can post?
Sure thing. Not much here though. One from each drive just in case. Are there any other logs??
Also, I did check to make sure DNS wasn't acting hinky on me. It's fine. Or seems to be at any rate.
MakeMKV_log-1.txt
(1.34 KiB) Downloaded 892 times
MakeMKV_log.txt
(1.28 KiB) Downloaded 847 times
003332:0000 Saved AACS dump file as file:///file/system/place/MakeMKV/MKB20_v76_F9_D24C.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
That's pretty much it in a nutshell. Email that .tgz file to svq@makemkv.com.
Even though others have posted that the disc is decrypting for them, it is sometimes the case that the same title has multiple encryption keys. This is a reason why it is helpful to post which key you submit. In your case, you've got key "D24C". Someone else very likely submitted a different key, which had a different file name.
ionblue
Post by ionblue »
dcoke22 wrote: Fri Sep 24, 2021 12:15 am
Even though others have posted that the disc is decrypting for them, it is sometimes the case that the same title has multiple encryption keys. This is a reason why it is helpful to post which key you submit. If your case, you've got key "D24C". Someone else very likely submitted a different key, which had a different file name.
Already sent another one today. I’ll try not to keep being a pest about it. Didn’t realize there could be multiple keys.
Thanks much.
