Hello, all!
Firstly, apologies for my first post being a cry for help. I'm sure it's common, but it seems a little rude.
I recently purchased a BU40N, which was working perfectly with MakeMKV. I had to remove the drive from my machine for a week or two (for unrelated reasons). I recently hooked the drive back up, and as soon as I powered the machine up, the tray ejected and will not stay closed.
Windows can see the drive, and if I insert a disc and hold the tray closed, the activity light flashes, but it doesn't appear to spin up. Holding the drive closed, with a disc inserted, and double clicking the drive in 'My Computer' just says "Please insert a disk [...]".
In a futile attempt to debug the problem, I tried flashing firmware (which I remembered requires the tray to be closed). So, my first attempt, I left the tray open and makemkvcon64.exe told me the "Drive tray is open, please close it". So I held it closed, up-entered and flashed the firmware with no problem.
I'm at a loss as to what else I can try to do to bring the drive back to life, it's only about 2 months old.
My current thinking is that I should just restore the stock firmware, using BU40N_1.04.exe, and RMA it.
Has anyone encountered this issue before, and, if so, did you have any luck in resolving it?
Many thanks!
BU40N tray won't stay closed (when there's power to the drive)
reewarb
Re: BU40N tray won't stay closed (when there's power to the drive)
No never seen that the only thing I can think of is make sure the button is not stuck in
