Default Optical Drive
deerewright
Post by deerewright » Mon Sep 13, 2021 4:30 pm
Is there a way to set a default drive for MakeMKV? I have an internal and an external. The external is faster and UHD official. I would like makemkv to load up the external as the default, but the way it works now, it loads up the internal first.
I am using this on a Linux (Ubuntu) server.
Re: Default Optical Drive
Post by Woodstock » Mon Sep 13, 2021 4:42 pm
You can change which drive is being looked at with the "Source" pull-down on the main window. And with a second drive, you can select "Ask for single-drive mode", which will then prompt for which drive to use on start-up.
deerewright
Post by deerewright » Thu Sep 16, 2021 5:25 pm
Woodstock wrote: Mon Sep 13, 2021 4:42 pm You can change which drive is being looked at with the "Source" pull-down on the main window. And with a second drive, you can select "Ask for single-drive mode", which will then prompt for which drive to use on start-up.
I don't see the option for "Ask for single-drive mode".
I am using the linux version if that matters.
Post by dcoke22 » Thu Sep 16, 2021 5:52 pm
It is on the IO tab in Preferences (on my macOS version anyway).
deerewright
Post by deerewright » Thu Sep 16, 2021 6:02 pm
dcoke22 wrote: Thu Sep 16, 2021 5:52 pm It is on the IO tab in Preferences (on my macOS version anyway).
Found it, thanks.
