fatez
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by fatez »
Good evening to all the forum,
I would like to buy an external player to back up my 4K, I've seen these models but I can't figure out if they work or not, could you kindly help me out?
- MD-8102P-U3YC-UHDB-K
- MD-8107S-U3YC+BDRW-S
- ‎MD-8102S-U3+UJ272(K)
thanks
liamtoh1
Post by liamtoh1 »
fatez wrote: Sat Sep 11, 2021 7:53 pm Good evening to all the forum,
thanks
Please read the 1st post of this thread for the drives that will allow you to rip / backup your 4K discs. You can also buy any one drive from that list and put it in an external enclosure.
thanks
No, none of those Archgon's are compatible. Only the MD-8107S-U3YC-UHD is capable as it contains a BU40N drive inside.
fatez
Post by fatez »
MartyMcNuts wrote: Sun Sep 12, 2021 1:41 am
But From Amazon : ‎MD-8107S-U3YC-UHDB-S "Archgon Style UHD External 4K-Ultra HD Blue BD Player, Blu-ray BDXL Burner for PC USB 3.0 USB-C, M-Disc, Native 4K USB UltraHD BluRay Players, Protection Box, Alu Silver"
An Amazon user said that "The Style has an LG brand BD-RE BU40N, the Star a Pioneer BDR-UD04. The Star is better in compatibility and quietness."
So if it's true that the Style has the BD-RE BU40N I can rest assured that it's compatible with makemkv for backing up my 4K?
fatez wrote: Sun Sep 12, 2021 7:24 am
Yes, the model(s) containing a BU40N are 4K compatible. The Pioneer's are not.
fatez
Post by fatez »
It has just arrived!
and mounts the BU40N :) , what firmware should I put exactly?
thank you very much!
ancient
Post by ancient »
fatez wrote: Tue Sep 14, 2021 4:33 pm
All the info is on the 1st page, very clearly laid out.
DE_LG_BU40N_1.00 is the best for your drive.
fatez
Post by fatez »
Thank you so much!
I succeeded and it works fine. (I'm trying right now to back up Blade Runner Uncut 4K).
So we can say that this MD-8107S-U3YC-UHDB-S works great.
Again thank you very much!
_nmd_
Post by _nmd_ »
I just got a BH16NS40 / SVC:NS51, here's the information I get:
Product: BD-RE BH16NS40
Revision: 1.02
Serial number: (hidden)
Firmware date: 2115-12-11 14:36
Highest AACS version: 68
Firmware version: 1.02
From this information, do I still have to flash in order to read UHD disks, or is it actually unneeded (as everything is marked OK)? I thought flashing was necessary for all UHD friendly drives, but I'm not sure how to interpret this report...
I don't have UHD disks yet (was waiting to have an enabled drive before I'd start buying), otherwise I'd already be testing of course.
Post by d00zah »
_nmd_ wrote: Sat Oct 02, 2021 12:47 am LibreDrive Information
Good to go for all that MakeMKV has to offer.
Zimonio
Post by Zimonio »
Sorry if this has been asked but how do I find out if my drive has encrypted or unencrypted firmware? I just got the Asus BW-16D1HT and want to flash it but I can't figure out if I should use the cmd prompt with the "enc" extension or not.
My drive info in MakeMKV if it's of use:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLDL3AJ1630
Bus encryption flags: 1F
Highest AACS version: 58
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Post by d00zah »
Zimonio wrote: Mon Oct 04, 2021 5:16 pm Sorry if this has been asked but how do I find out if my drive has encrypted or unencrypted firmware? I just got the Asus BW-16D1HT and want to flash it but I can't figure out if I should use the cmd prompt with the "enc" extension or not.
The 1st post in this thread has a list of known encrypted FWs (& MANY other things) . It remains the "definitive guide" on this topic.
Mr_Orange
Post by Mr_Orange »
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
If you download and use SDFTool Flasher, it will do the hard work for you. You will need the latest version available from the dedicated thread.
Zimonio
Post by Zimonio »
Mr_Orange wrote: Mon Oct 04, 2021 11:55 pm
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Thanks for answering! I tried using this but I just got the error that my "api-ms-win-core-winrt-l1-1-0.dll" is missing on my computer and I can't find a way around it. Could I still be able to manually flash it?
