Happy P8 making
Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
Happy P8 making
Happy P8 making
@ quietvoid
L2 meta keep coming out weird.
But on the xml it seem to be correct well (not 100% sure it’s correct.)
What could be the reason for this?
Just curious if u got any insight on this from others ellse were
So far I get a perfect l1DV meta match from resolve min-average-max are all correct
For spares & munsil compare to the original
I don't know, I've mentioned that the L2 doesn't always match in the RPU.Manixx2020beyound wrote: ↑Sun Sep 12, 2021 4:49 pm@ quietvoid
My only test samples are Netflix's encoded streams, and the corresponding CMv2.9 XML.
Sometimes it's fine, sometimes the values are different.
I wonder if the monitor I’m using plays a part, I’ll try & find out.quietvoid wrote: ↑Sun Sep 12, 2021 5:31 pmI don't know, I've mentioned that the L2 doesn't always match in the RPU.Manixx2020beyound wrote: ↑Sun Sep 12, 2021 4:49 pm@ quietvoid
cannibalist2
Could someone give me information about profile 4 vs profile 8?
As far as i know
Profile 4 supports enhancement layer but base layer is SDR compatible
Profile 8 is HDR compatible but doesnt support enhancement layer
My tv is lg g1 and internal plex app can play both profiles (p4 st dl/dt dl and p8 st sl). Why are we focusing on converting FEL movies to profile 8 instead of profile 4? I have made only one movie so far with both profiles and they looked like same to me.
As far as i know
Because you're not actually converting anything when using profile 4, just changing the container.cannibalist2 wrote: ↑Mon Sep 13, 2021 3:39 pmMy tv is lg g1 and internal plex app can play both profiles (p4 st dl/dt dl and p8 st sl). Why are we focusing on converting FEL movies to profile 8 instead of profile 4? I have made only one movie so far with both profiles and they looked like same to me.
Profile 4 is not compatible with HDR10 video such as UHD discs.
Profile 5 includes reshaping metadata and some different flags/values for the color space.
Otherwise the actual dynamic metadata should be the same.
The reshaping process recreates the YCbCr image, with supposedly close to 12 bits equivalent info.
The profile 5 proprietary colorspace is more efficient, see https://en.wikipedia.org/wiki/ICtCp#Characteristics
In reality FEL can also add detail/noise, so they're not the same.
Is anyone else here for FEL titles encoding their HDR10 BL to a smaller size and then making p8 with RPU from EL and also remuxing together with EL again for SL p7 FEL (in different files each, duh-doy - not trying to make that all in 1 file or something)? I'm getting random non-constant color/video artifacting in numerous titles after encoding and making both p8 and p7 SL and the artifacts are not there in the encoded BL (not just Handbrake btw, I've tried ffmpeg w/ x265 directly and others as well with the same artifacting results each time essentially, just the artifacts appear in different places/times depending on the encoder). I have things like chromaloc=2 set and stuff, but I know both the BL+EL in p7 work intertwined so to speak and are spit out together as two files at time of source encode w/ DV so I'm wondering if encoding at all afterwards no matter what breaks FEL or if I'm just missing/breaking a specific flag/setting somewhere. MEL only titles are fine after encoding with no artifacting, but they don't have as much going on with complexity so not as much to break. Playback is also obviously fine for FEL if I make the files without encoding the BL. But I also can't burn in forced subtitles then. :/
-max_muxing_queue_size 1024 -map 0:0 -c:v libx265 -pix_fmt yuv420p10le -profile:v main10 -x265-params "level-idc=51:high-tier=1:uhd-bd=1:ref=5:aq-mode=2:repeat-headers=1:strong-intra-smoothing=1:bframes=4:b-adapt=2:frame-threads=0:colorprim=bt2020:transfer=smpte2084:colormatrix=bt2020nc:hdr10_opt=1:master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1):max-cll=0,0:hdr10=1:chromaloc=2:pass=1:no-slow-firstpass=1" -b:v 44808k -preset:v medium -an -sn -dn -f mp4 NUL -
No issue on my end with x265.exe (staxrip GUI)
x265.exe --crf 14 --preset slower --profile main10 --level-idc 5.1 --output-depth 10 --vbv-bufsize 160000 --vbv-maxrate 160000 --master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,50)" --hdr10 --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --max-luma 1023 --max-cll "1232,278" --hdr10-opt --dolby-vision-profile 8.1 --dolby-vision-rpu X:\RPU.metadata.bin --repeat-headers --hrd --aud --no-open-gop --deblock -3:-3 --no-sao --chromaloc 2Re: Dolby Vision now possible through MP4 Mux.
I'mma try again with x265 keeping it real simple
I wasn't doing the DV insertion at time of encode like you are, because I was trying to make a p7 mux and p8 from the same HDR10 only base encode, though that shouldn't matter; but I'm in trial and error mode so if this next one doesn't work I'll try that.
--pass 1 --bitrate 44808 --output-depth 10 --profile main10 --level-idc 5.1 --high-tier --ref 5 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --hdr10 --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --chromaloc 2 --repeat-headers --aud --hrd --statsRe: Dolby Vision now possible through MP4 Mux.
Sorry if it was asked before, can your tool convert from Profile 7/8 to Profile 5?quietvoid wrote: ↑Tue Sep 14, 2021 3:48 pmThe profile 5 proprietary colorspace is more efficient, see https://en.wikipedia.org/wiki/ICtCp#Characteristics
