The Social Network
mike5215
The Social Network
#1 Post by mike5215 » Tue Feb 15, 2011 12:52 am
Error: This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?AgIC...
Issue resolved using DVDFab8 to rip to folder, then MakeMKV to create a playable file.
setarip_old
Re: The Social Network
#2 Post by setarip_old » Tue Feb 15, 2011 1:46 am
@mike5215
Hi!
Just to let you know I had no problems using MakeMKV to do a full disc backup of "The Social Network".
1) What version of MakeMKV did you initially use when trying to backup your original, commercial Blu-ray disc?
2) Did you try cleaning your original disc and then re-try using MakerMKV to make the backup?
3) The DVDFab group of programs all have the reputation of skipping over errors in order to complete a rip. Have you played the "successful" rip to make sure it doesn't exhibit any problems?
bluewizard
#3 Post by bluewizard » Wed Feb 16, 2011 5:43 pm
mike5215 wrote:Error: This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?AgIC...
@mike5215: Do you know what region this disc is from?
Maybe Mike5215 has a non Region A disc....
mike5215
#4 Post by mike5215 » Fri Feb 18, 2011 12:36 am
setarip_old wrote:@mike5215
Hi!
1.5.5
The disc is okay, plays fine.
Haven't yet. Spot checked only. I don't typically use DVD Fab for BR, but I did use it for several hundred DVD rips with no problems.
mike5215
#5 Post by mike5215 » Fri Feb 18, 2011 2:59 pm
Watched the full MKV (derived from the DVDFab decrypted file) last night, no errors.
setarip_old
#6 Post by setarip_old » Fri Feb 18, 2011 7:08 pm
1.5.5
Unless this is a typo ("1.55"), your problem is due to using a VERY outdated version of MakeMKV (April 2010)
But did you try cleaning it and then re-try using MakerMKV to make the backup?
choongmin
#7 Post by choongmin » Fri Mar 07, 2014 1:55 pm
Hi. I have a Two-Disc Collector's Edition. In the first disc, among 7 titles (min length 10 sec), the first one (MPEG2, LPCM Stereo, 00099.mpls, 7:05, 1.1 GB) cannot be ripped. Following are debug messages:
Saving 1 titles into directory D:/Videos/The Social Network
DEBUG: Code 268614528 at aU6O@0b|?Id}aL<Q,Sm.:213137160
DEBUG: Code 0 at aU6O@0b|?Id}aL<Q,Sm.:121268972
DEBUG: Code 0 at juE@~sQm5j .>lx:121263429
DEBUG: Code 1 at Ke"dTt{1X]=2a,;;P]:213131272
DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121263084
LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213132560
DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:29397794
DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213135251
DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121267914
Failed to save title 0 to file D:/Videos/The Social Network/Social_Network,_The_t00.mkv
0 titles saved, 1 failed
Should I send a debug dump file?
#8 Post by Woodstock » Fri Mar 07, 2014 9:32 pm
You should update to 1.8.9, which fixes the "LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available" error.
