I found one of my aunt's favorite old movies but it was only available as a Region B Blu-ray. I figured I would rip it and write it as a region-free disc for her, but it's proving harder than I thought.
My MakeMKV backup worked fine, but I can't figure out how to write that backup to a disc without the Region B code.
ImgBurn doesn't have that option as far as I can tell and all my google-fu has failed me. Any suggestions?
Blu-ray Backup works, but how can I write the backup to disc with no region code?
legolad
Re: Blu-ray Backup works, but how can I write the backup to disc with no region code?
If you're trying to make a BD that doesn't care about regions, you'll have to replace the menus, which is where the region coding is enforced. Of course, that kind of defeats the reason for doing a "full disk backup"...
A simpler approach is really to write to MKV files, ignore the menus, and give your aunt a media player that can read something other than BDs. MKV files do not have region coding.
legolad
Thanks. Sadly she struggles with technology so anything new (like playing from an MKV) is just too much for her.Woodstock wrote: Tue Sep 14, 2021 12:44 pm A simpler approach is really to write to MKV files, ignore the menus, and give your aunt a media player that can read something other than BDs. MKV files do not have region coding.
Frankly I'm surprised she can navigate disc menus.
I guess I'll create a new Bluray menu for her.
