Zack Snyder's Justice League 4K UHD (UK)
Just emailed the dump files.
Re: Zack Snyder's Justice League 4K UHD (UK)
No email bouncing here. Hoping Mike and crew are able to fix this.
How long does it typically take for the decryption keys to be generated since submitting the AACS dumps?
does this have Dolby vision
Works now. Thanks very much.
anyone knows how many frames from end of D1 and beginning of D2 cut to joing into 1 MKV?
I don't know the frames but I have been looking at how to merge the two discs together.
My copy came today and so far it has backed up great. I was going to move it over to the Plex server and run a quick test because it is supposed to automatically play the second disc if named properly. Of course I have yet to get this to work properly but I only have done this once before with Lord of the Rings.
Seamless playback would be ideal though.
Yeah I merged my Lord of the Rings rips together with MakeMKV to tighten up that gap between them. Plex will go from part 1 to part 2 automatically if you keep them separate files, but some things didn't seem to work right, like the play bar (showing how much time is left) and chapters in the second half, you couldn't jump forward to them. Merging into one file made everything Just Work again.
Found a post on Reddit where someone described the timestamps they used to split. They split the video and audio separately, which I hadn't done before:
https://www.reddit.com/r/Bluray/comment ... uray_info/i split the first part's video at frame 204010 (8508.92 seconds), and the first part's audio at 8510.92 seconds. i then cut the second part's video at 2 seconds and the audio at 4 seconds. i combined the audio and the video seperately, and then put the audio back into the video, and voila, a full 4 hour video file of the whole film
I just bought this at Target yesterday... went to rip today and it says "No Disc". I have cleaned the disc and got the same problem. Any advice?
charnathan
It's a triple layer disc, so it'll take a few times before it's recognized.Wolf359 wrote: Wed Sep 08, 2021 7:04 pm I just bought this at Target yesterday... went to rip today and it says "No Disc". I have cleaned the disc and got the same problem. Any advice?
I got it to eventually recognize on my asus drive and the hash key's haven't been made for the US release.
I submitted the dumps. I'd suggest you do the same when you get it to finally recognize the disc.
OK. Thanks. I will figure out how to submit the dumps.charnathan wrote: Wed Sep 08, 2021 7:27 pmIt's a triple layer disc, so it'll take a few times before it's recognized.Wolf359 wrote: Wed Sep 08, 2021 7:04 pm I just bought this at Target yesterday... went to rip today and it says "No Disc". I have cleaned the disc and got the same problem. Any advice?
Submitted dump file for first disc. Should I do the second disc as well? Or are the keys the same?
See this post: viewtopic.php?p=108809#p108809Wolf359 wrote: Wed Sep 08, 2021 8:02 pm Submitted dump file for first disc. Should I do the second disc as well? Or are the keys the same?
The short version is the title of the .tgz file has a hash in it. If the title and hash is the same for both discs, the key is the same. If they're different, then there's different keys.
