Blu Ray extras but not the movie
catdeskchaos
#1 Post by catdeskchaos » Sun Sep 12, 2021 5:54 am
I am brand new to this. I am sorry if my problem came up before or if there is an introduction that I missed. I looked around but I couldn't find an answer.
I have copied some Blu Rays but I'm having a problem with others where I will get all the extras but not the movie. The most recent one I have had this problem with is the Criterion Collection Blu Ray of the 39 Steps.
I can see what I think is the movie when it shows me things I can copy, but when I ask it to it tells me 0 titles were copied, and then it bounces me back to the selection.
I've cleaned the discs, and this has happened to some other blu rays as well.
I am using an archgon and my system is windows 10 if that matters.
Re: Blu Ray extras but not the movie
#2 Post by dcoke22 » Sun Sep 12, 2021 4:08 pm
The bottom half of the MakeMKV window shows a log of what's going. With one of the discs you're having trouble with, copy that log and paste it into this thread so we can see what's going on.
You can put it in a 'code' block show it shows up like this.
catdeskchaos
#3 Post by catdeskchaos » Sun Sep 12, 2021 6:57 pm
Ok, so I put the disk in, have it scan. The log shows this.
MakeMKV v1.16.4 win(x64-release) started
Evaluation version, 22 day(s) out of 30 remaining
File 00001.mpls was added as title #0
File 00801.mpls was added as title #1
File 00805.mpls was added as title #2
File 00021.mpls was added as title #3
Title #00230.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00295.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00304.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00305.m2ts was added as title #4
File 00307.m2ts was added as title #5
File 00308.m2ts was added as title #6
I look at the things I can copy. I have all the extras already so I deselect most of them. I'm fairly sure this is the movie so this is the only one I have check marked.
Title information
Name: THE 39 STEPS
Source file name: 00001.mpls
Duration: 1:26:45
Chapters count: 12
Segment count: 1
Segment map: 274
File name: THE 39 STEPS_t00.mkv
Tell it to save to my The 39 Steps - Criterion on my external hard drive. Start by clicking the Make MKV button.
Saving 1 titles into directory E:/The 39 Steps - Criterion
Title 0 skipped
0 titles saved
catdeskchaos
#4 Post by catdeskchaos » Sat Sep 25, 2021 2:13 am
I got a new external hard drive with a different format and haven't had this issue since. So I guess if anyone else has this issue use NTFS format.
NullNix
#5 Post by NullNix » Mon Oct 11, 2021 9:25 pm
Ah, that explains it. Older disks are probably formatted with one of the versions of the FAT filesystem which cannot handle files >2GiB in size: the main movie is almost certainly much bigger than that, so writing fails. (You'd usually get a truncated 2GiB file, though, not nothing.)
Disks formatted more recently are probably either NTFS (as noted) or ExFAT, neither of which have this problem.
