is svq@makemkv.com working?
ravedog
Post by ravedog »
I have sent two keysand log files to svq@makemkv.com in the last couple months and gotten no response. Does anyone answer this account?
Thank you
Re: is svq@makemkv.com working?
ravedog wrote:
Sun Sep 12, 2021 2:06 am
Thank you
no response is normal it just adds to the list to be decrypted
ravedog
Post by ravedog »
Billycar11 wrote:
Sun Sep 12, 2021 2:08 am
Cool. But it seems that Im still having problems with a couple discs - that others have posted it working then. So how should I approach this?
do you see failed to update hk when you go to rip a disc it has been updating multiple time's a week lately
ravedog
Post by ravedog »
Billycar11 wrote:
Sun Sep 12, 2021 2:13 am
Debug log started at Sun Sep 12 02:17:58 2021 , written by MakeMKV v1.16.4 darwin(x64-release)
001005:0000 MakeMKV v1.16.4 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/ravedog/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.64.1/(SecureTransport) LibreSSL/2.8.3 (x86_64-apple-darwin19.0) , proxy server not set.
002010:0000 Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
SDF  v07e: ASUS_BW-16D1HT_3.10_211901041014_KL4K5991951
001011:0000 Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
DEBUG: Code 2147483648 at rhHV->i@V}3]oyDy:121264625
003338:0000 Downloading latest HK to /Volumes/sahara/ scratches/MakeMKV ...
001003:0020 DEBUG: Code 2400288775 at 1CE^z7y\P*zV;k?:29393999
001003:0020 DEBUG: Code 0 at rhHV->i@V}3]oyDy:121267362
003339:0000 Automatic HK downloading is disabled or failed.
003332:0000 Saved AACS dump file as file:///Volumes/sahara/ scratches/MakeMKV/MKB20_v76_The_Thing_3924.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at HE<hEO<!JUR7.k';:29396092
001003:0020 DEBUG: Code 0 at HE<hEO<!JUR7.k';:29395172
That's your problem
Your isp/dns is blocking it try changing your dns and make sure you didn't disable it
ravedog
Post by ravedog »
Billycar11 wrote:
Sun Sep 12, 2021 4:06 am
That's your problem
So that seems to have fixed the problem with the key. But alas, I'm having issues with the drive itself that I got at the beginning of the year from someone here and after a month of attempting to getting him to replace it - he has basically vanished. Back to square one... Recommend anyone for sells modded drives that honors them too ? (I have a mac and can't do the work myself)...
Thank you so much for solving this part of it...
G
ravedog wrote:
Sun Sep 12, 2021 7:18 am
That's your problem
G
yeah me i sell them linked below
but usa only
ravedog
Post by ravedog »
Billycar11 wrote:
Sun Sep 12, 2021 8:21 am
That's your problem
G
but usa only
Thanks B - I'll email you....
