fatez
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by fatez » Sat Sep 11, 2021 7:53 pm
Good evening to all the forum,
I would like to buy an external player to back up my 4K, I've seen these models but I can't figure out if they work or not, could you kindly help me out?
- MD-8102P-U3YC-UHDB-K
- MD-8107S-U3YC+BDRW-S
- ‎MD-8102S-U3+UJ272(K)
thanks
liamtoh1
Post by liamtoh1 » Sat Sep 11, 2021 8:49 pm
thanks
Please read the 1st post of this thread for the drives that will allow you to rip / backup your 4K discs. You can also buy any one drive from that list and put it in an external enclosure.
Post by MartyMcNuts » Sun Sep 12, 2021 1:41 am
thanks
No, none of those Archgon's are compatible. Only the MD-8107S-U3YC-UHD is capable as it contains a BU40N drive inside.
fatez
Post by fatez » Sun Sep 12, 2021 7:24 am
But From Amazon : ‎MD-8107S-U3YC-UHDB-S "Archgon Style UHD External 4K-Ultra HD Blue BD Player, Blu-ray BDXL Burner for PC USB 3.0 USB-C, M-Disc, Native 4K USB UltraHD BluRay Players, Protection Box, Alu Silver"
An Amazon user said that "The Style has an LG brand BD-RE BU40N, the Star a Pioneer BDR-UD04. The Star is better in compatibility and quietness."
So if it's true that the Style has the BD-RE BU40N I can rest assured that it's compatible with makemkv for backing up my 4K?
Post by MartyMcNuts » Sun Sep 12, 2021 11:38 pm
Yes, the model(s) containing a BU40N are 4K compatible. The Pioneer's are not.
fatez
Post by fatez » Tue Sep 14, 2021 4:33 pm
It has just arrived!
and mounts the BU40N :) , what firmware should I put exactly?
thank you very much!
ancient
Post by ancient » Tue Sep 14, 2021 10:38 pm
All the info is on the 1st page, very clearly laid out.
Post by MartyMcNuts » Wed Sep 15, 2021 2:08 am
DE_LG_BU40N_1.00 is the best for your drive.
fatez
Post by fatez » Wed Sep 15, 2021 5:49 pm
Thank you so much!
I succeeded and it works fine. (I'm trying right now to back up Blade Runner Uncut 4K).
So we can say that this MD-8107S-U3YC-UHDB-S works great.
Again thank you very much!
_nmd_
Post by _nmd_ » Sat Oct 02, 2021 12:47 am
I just got a BH16NS40 / SVC:NS51, here's the information I get:
Product: BD-RE BH16NS40
Revision: 1.02
Serial number: (hidden)
Firmware date: 2115-12-11 14:36
Highest AACS version: 68
Firmware version: 1.02
From this information, do I still have to flash in order to read UHD disks, or is it actually unneeded (as everything is marked OK)? I thought flashing was necessary for all UHD friendly drives, but I'm not sure how to interpret this report...
I don't have UHD disks yet (was waiting to have an enabled drive before I'd start buying), otherwise I'd already be testing of course.
Post by d00zah » Sat Oct 02, 2021 2:49 pm
Good to go for all that MakeMKV has to offer.
Zimonio
Post by Zimonio » Mon Oct 04, 2021 5:16 pm
Sorry if this has been asked but how do I find out if my drive has encrypted or unencrypted firmware? I just got the Asus BW-16D1HT and want to flash it but I can't figure out if I should use the cmd prompt with the "enc" extension or not.
My drive info in MakeMKV if it's of use:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLDL3AJ1630
Bus encryption flags: 1F
Highest AACS version: 58
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Post by d00zah » Mon Oct 04, 2021 11:49 pm
The 1st post in this thread has a list of known encrypted FWs (& MANY other things) . It remains the "definitive guide" on this topic.
Mr_Orange
Post by Mr_Orange » Mon Oct 04, 2021 11:55 pm
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
If you download and use SDFTool Flasher, it will do the hard work for you. You will need the latest version available from the dedicated thread.
Zimonio
Post by Zimonio » Tue Oct 05, 2021 7:26 am
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Thanks for answering! I tried using this but I just got the error that my "api-ms-win-core-winrt-l1-1-0.dll" is missing on my computer and I can't find a way around it. Could I still be able to manually flash it?
