Ultimate UHD Drives Flashing Guide Updated 2025
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Good evening to all the forum,
I would like to buy an external player to back up my 4K, I've seen these models but I can't figure out if they work or not, could you kindly help me out?
- MD-8102P-U3YC-UHDB-K
- MD-8107S-U3YC+BDRW-S
- MD-8102S-U3+UJ272(K)
thanks
thanks
Please read the 1st post of this thread for the drives that will allow you to rip / backup your 4K discs. You can also buy any one drive from that list and put it in an external enclosure.fatez wrote: ↑Sat Sep 11, 2021 7:53 pmGood evening to all the forum,
thanks
No, none of those Archgon's are compatible. Only the MD-8107S-U3YC-UHD is capable as it contains a BU40N drive inside.fatez wrote: ↑Sat Sep 11, 2021 7:53 pmGood evening to all the forum,
thanks
MartyMcNuts wrote: ↑Sun Sep 12, 2021 1:41 am
But From Amazon : MD-8107S-U3YC-UHDB-S "Archgon Style UHD External 4K-Ultra HD Blue BD Player, Blu-ray BDXL Burner for PC USB 3.0 USB-C, M-Disc, Native 4K USB UltraHD BluRay Players, Protection Box, Alu Silver"
An Amazon user said that "The Style has an LG brand BD-RE BU40N, the Star a Pioneer BDR-UD04. The Star is better in compatibility and quietness."
So if it's true that the Style has the BD-RE BU40N I can rest assured that it's compatible with makemkv for backing up my 4K?
Yes, the model(s) containing a BU40N are 4K compatible. The Pioneer's are not.fatez wrote: ↑Sun Sep 12, 2021 7:24 amMartyMcNuts wrote: ↑Sun Sep 12, 2021 1:41 am
It has just arrived!MartyMcNuts wrote: ↑Sun Sep 12, 2021 1:41 am
and mounts the BU40N
thank you very much!
All the info is on the 1st page, very clearly laid out.fatez wrote: ↑Tue Sep 14, 2021 4:33 pmIt has just arrived!MartyMcNuts wrote: ↑Sun Sep 12, 2021 1:41 am
and mounts the BU40N, what firmware should I put exactly?
DE_LG_BU40N_1.00 is the best for your drive.fatez wrote: ↑Tue Sep 14, 2021 4:33 pmIt has just arrived!MartyMcNuts wrote: ↑Sun Sep 12, 2021 1:41 am
Thank you so much!
I succeeded and it works fine. (I'm trying right now to back up Blade Runner Uncut 4K).
So we can say that this MD-8107S-U3YC-UHDB-S works great.
Again thank you very much!
I just got a BH16NS40 / SVC:NS51, here's the information I get:
Product: BD-RE BH16NS40
Revision: 1.02
Serial number: (hidden)
Firmware date: 2115-12-11 14:36
Highest AACS version: 68
Firmware version: 1.02
From this information, do I still have to flash in order to read UHD disks, or is it actually unneeded (as everything is marked OK)? I thought flashing was necessary for all UHD friendly drives, but I'm not sure how to interpret this report...
I don't have UHD disks yet (was waiting to have an enabled drive before I'd start buying), otherwise I'd already be testing of course.
Revision: 1.02
Good to go for all that MakeMKV has to offer.
Sorry if this has been asked but how do I find out if my drive has encrypted or unencrypted firmware? I just got the Asus BW-16D1HT and want to flash it but I can't figure out if I should use the cmd prompt with the "enc" extension or not.
My drive info in MakeMKV if it's of use:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLDL3AJ1630
Bus encryption flags: 1F
Highest AACS version: 58
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
The 1st post in this thread has a list of known encrypted FWs (& MANY other things) . It remains the "definitive guide" on this topic.
If you download and use SDFTool Flasher, it will do the hard work for you. You will need the latest version available from the dedicated thread.Zimonio wrote: ↑Mon Oct 04, 2021 5:16 pmSorry if this has been asked but how do I find out if my drive has encrypted or unencrypted firmware? I just got the Asus BW-16D1HT and want to flash it but I can't figure out if I should use the cmd prompt with the "enc" extension or not.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Thanks for answering! I tried using this but I just got the error that my "api-ms-win-core-winrt-l1-1-0.dll" is missing on my computer and I can't find a way around it. Could I still be able to manually flash it?Mr_Orange wrote: ↑Mon Oct 04, 2021 11:55 pmIf you download and use SDFTool Flasher, it will do the hard work for you. You will need the latest version available from the dedicated thread.Zimonio wrote: ↑Mon Oct 04, 2021 5:16 pmSorry if this has been asked but how do I find out if my drive has encrypted or unencrypted firmware? I just got the Asus BW-16D1HT and want to flash it but I can't figure out if I should use the cmd prompt with the "enc" extension or not.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
