Indian Summers S02 - Obfuscation
Plex_Guy
Post by Plex_Guy »
Just finished up working on Season 2, here are the .mpls results:
Disc 1: 577,855,962
Disc 2: 402,821,677
Disc 3: 513,515,659
Disc 4: 821
Old, but perhaps of some use.
thetoad
Re: Indian Summers S02 - Obfuscation
Post by thetoad »
many recent PBS releases are like this. But in fact, they really aren't java disc, the java code can be totally removed and the discs will play back perfectly (menus and all) if setup correctly. i.e. all the java code does is set 3 register variables to the the correct playlist and then the non java menu code knows to use this registers to choose which playlist to play. AnyDVD's decryption recognizes this, excises the java code from the playback and just sets the register values manually so that the non java code will work as expected. This then means one can trim out the bloated java directory which is no longer needed for playback.
