mulucy
Post by mulucy » Thu Sep 09, 2021 9:07 pm
staknhalo wrote:
Thu Sep 09, 2021 8:28 pm
Don't products like DVDFab remove cinavia or is it through encoding not just 'muxing' it out or whatever?
Cinavia is already dead. Most studios don't use it anymore. With the introduction of DRM with online streaming and piracy through 3rd-party players, the cost of it no longer was justified. But I think you are right, DVD Fab has the ability to remove it.
mulucy
Post by mulucy » Thu Sep 09, 2021 9:08 pm
The new Fire TV Stick came out today - https://www.amazon.com/dp/B08MQZXN1X/re ... CB5HMB36RE. Wonder if the new GPU/CPU supports more DV profiles lol
quietvoid
Post by quietvoid » Thu Sep 09, 2021 9:40 pm
I've preordered one for AV1, but the speed upgrade is welcomed.
Any Dolby Vision improvement is a bonus to me.
mulucy
Post by mulucy » Fri Sep 10, 2021 2:18 am
I tried to find some information about the CPU, but found nothing. Very strange...
dysprosium
Post by dysprosium » Fri Sep 10, 2021 4:40 am
https://developer.amazon.com/docs/fire- ... stick4kmax
Mediatek MT8696
Dolby Vision support for Profile 4-MEL, 5, 8, 9. (Up to Level 9 for profiles 5 and 8. Up to Level 5 for Profile 9.)
mulucy
Post by mulucy » Fri Sep 10, 2021 6:06 pm
Mediatek MT8696
Good stuff, pretty much the same DV support. Thank you!
Pixels
Post by Pixels » Sat Sep 11, 2021 3:39 pm
I've converted the profile 7 to profile 5 DV using mp4muxer.
After extracting the single layer profile 7 mkv
File size                                : 81.3 GiB
Duration                                 : 2 h 34 min
Overall bit rate                         : 75.3 Mb/s
Movie name                               : Transformers: The Last Knight (2017) DV
Encoded date                             : UTC 2021-02-18 10:28:06
Writing application                      : mkvmerge v53.0.0 ('Fool's Gold') 64-bit
Writing library                          : libebml v1.4.1 + libmatroska v1.6.2
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 69.1 Mb/s
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 74.6 GiB (92%)
Audio
Format settings                          : Dolby Surround EX
Codec ID                                 : A_AC3
Stream size                              : 708 MiB (1%)
Title                                    : AC-3 5.1-EX
to profile 5 DV mp4 as it triggers DV in my laptop
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 75.3 GiB
Overall bit rate                         : 69.7 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Stream size                              : 74.6 GiB (99%)
Encoded date                             : UTC 2021-08-30 18:13:04
Tagged date                              : UTC 2021-08-30 18:13:04
Codec configuration box                  : hvcC+dvcC+hvcE
Audio
Codec ID                                 : ac-3
The problem is that the Audio is delayed, I went through the forum and found I had to to use dovi_tool, how do i proceed..?
staknhalo
Post by staknhalo » Sat Sep 11, 2021 11:38 pm
Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
Happy P8 making :)
Post by Manixx2020beyound » Sun Sep 12, 2021 4:49 pm
@ quietvoid
L2 meta keep coming out weird.
But on the xml it seem to be correct well (not 100% sure it’s correct.)
What could be the reason for this?
Just curious if u got any insight on this from others ellse were
So far I get a perfect l1DV meta match from resolve min-average-max are all correct
For spares & munsil compare to the original
quietvoid
Post by quietvoid » Sun Sep 12, 2021 5:31 pm
@ quietvoid
I don't know, I've mentioned that the L2 doesn't always match in the RPU.
My only test samples are Netflix's encoded streams, and the corresponding CMv2.9 XML.
Sometimes it's fine, sometimes the values are different.
Post by Manixx2020beyound » Sun Sep 12, 2021 8:30 pm
@ quietvoid
I wonder if the monitor I’m using plays a part, I’ll try & find out.
cannibalist2
Post by cannibalist2 » Mon Sep 13, 2021 3:39 pm
Could someone give me information about profile 4 vs profile 8?
As far as i know
Profile 4 supports enhancement layer but base layer is SDR compatible
Profile 8 is HDR compatible but doesnt support enhancement layer
My tv is lg g1 and internal plex app can play both profiles (p4 st dl/dt dl and p8 st sl). Why are we focusing on converting FEL movies to profile 8 instead of profile 4? I have made only one movie so far with both profiles and they looked like same to me.
quietvoid
Post by quietvoid » Tue Sep 14, 2021 2:20 pm
Because you're not actually converting anything when using profile 4, just changing the container.
Profile 4 is not compatible with HDR10 video such as UHD discs.
staknhalo
Post by staknhalo » Tue Sep 14, 2021 2:39 pm
Is profile 5 just dynamic tonemapping metadata in a proprietary color space? So nothing unique in the experience really over a profile 8.1 file (assuming bitrate equal)? Or does profile 5 have specific 12bit color info in it like a profile 7 FEL?
quietvoid
Post by quietvoid » Tue Sep 14, 2021 3:00 pm
Profile 5 includes reshaping metadata and some different flags/values for the color space.
Otherwise the actual dynamic metadata should be the same.
The reshaping process recreates the YCbCr image, with supposedly close to 12 bits equivalent info.
