cannibalist2
Post by cannibalist2 »
Hello, is it possible to convert from truehd + atmos to eac3 + atmos and mux with dolby vision movies?
I have not a receiver so I have to stick to ac3/eac3 but eac3 + atmos is so much better than ac3/eac3.
Like this one
https://imgur.com/a/OhxObMu
mulucy
Post by mulucy »
RESET_9999 wrote: Wed Sep 08, 2021 9:31 pm
chros wrote: Wed Sep 08, 2021 6:47 pm
Oppo has issue upconverting hdr10+ to DoVi
why would you do that now that there's a tool that perfectly converts HDR10+ to true dynamic DV?
mulucy wrote: Wed Sep 08, 2021 2:09 pm This is from Sony's website Sony X700 owners:
Firmware update version M43.R.0284 for UBP-X700 | Release Dat 08-24-2021
  • Removes the Gracenote function
    Improves HDMI connection stability
    Supporting Dolby Vision content for Blu-ray Disc, Netflix and VUDU
    Supporting online streaming services
Have not updated mine yet. Whatever DV support means in the text above. Maybe they fixed the DV limitation where you had to know which movie/disk is DV to manually enable it?
Anyone updated yet and tried a Cinavia protected movie?
haven't updated my unit yet. Which titles have Cinavia? I thought the latter was thing of the past lol
mulucy wrote: Thu Sep 09, 2021 5:32 pm haven't updated my unit yet. Which titles have Cinavia? I thought the latter was thing of the past lol
cannibalist2 wrote: Thu Sep 09, 2021 12:57 pm Hello, is it possible to convert from truehd + atmos to eac3 + atmos and mux with dolby vision movies?
Like this one
I could be wrong but i think you need the Dolby encoding suite for that and I dont think it's cracked.
EDIT: scratch that. theres an old version on russian trackers. Dont know if it supports Atmos though
cannibalist2
RESET_9999 wrote: Thu Sep 09, 2021 7:08 pm
Like this one
Thanks, I thought so. Looks like there is no legal way for this unless you pay around 1000$
staknhalo
Post by staknhalo »
Don't products like DVDFab remove cinavia or is it through encoding not just 'muxing' it out or whatever?
mulucy
Post by mulucy »
staknhalo wrote: Thu Sep 09, 2021 8:28 pm Don't products like DVDFab remove cinavia or is it through encoding not just 'muxing' it out or whatever?
Cinavia is already dead. Most studios don't use it anymore. With the introduction of DRM with online streaming and piracy through 3rd-party players, the cost of it no longer was justified. But I think you are right, DVD Fab has the ability to remove it.
mulucy
Post by mulucy »
The new Fire TV Stick came out today - https://www.amazon.com/dp/B08MQZXN1X/re ... CB5HMB36RE. Wonder if the new GPU/CPU supports more DV profiles lol
quietvoid
Post by quietvoid »
I've preordered one for AV1, but the speed upgrade is welcomed.
Any Dolby Vision improvement is a bonus to me.
mulucy
Post by mulucy »
quietvoid wrote: Thu Sep 09, 2021 9:40 pm I've preordered one for AV1, but the speed upgrade is welcomed.
I tried to find some information about the CPU, but found nothing. Very strange...
dysprosium
Post by dysprosium »
mulucy wrote: Fri Sep 10, 2021 2:18 am I tried to find some information about the CPU, but found nothing. Very strange...
https://developer.amazon.com/docs/fire- ... stick4kmax
Mediatek MT8696
Dolby Vision support for Profile 4-MEL, 5, 8, 9. (Up to Level 9 for profiles 5 and 8. Up to Level 5 for Profile 9.)
mulucy
Post by mulucy »
dysprosium wrote: Fri Sep 10, 2021 4:40 am
Mediatek MT8696
Good stuff, pretty much the same DV support. Thank you!
Pixels
Post by Pixels »
I've converted the profile 7 to profile 5 DV using mp4muxer.
After extracting the single layer profile 7 mkv
File size                                : 81.3 GiB
Duration                                 : 2 h 34 min
Overall bit rate                         : 75.3 Mb/s
Movie name                               : Transformers: The Last Knight (2017) DV
Encoded date                             : UTC 2021-02-18 10:28:06
Writing application                      : mkvmerge v53.0.0 ('Fool's Gold') 64-bit
Writing library                          : libebml v1.4.1 + libmatroska v1.6.2
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 69.1 Mb/s
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 74.6 GiB (92%)
Audio
Format settings                          : Dolby Surround EX
Codec ID                                 : A_AC3
Stream size                              : 708 MiB (1%)
Title                                    : AC-3 5.1-EX
to profile 5 DV mp4 as it triggers DV in my laptop
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 75.3 GiB
Overall bit rate                         : 69.7 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Stream size                              : 74.6 GiB (99%)
Encoded date                             : UTC 2021-08-30 18:13:04
Tagged date                              : UTC 2021-08-30 18:13:04
Codec configuration box                  : hvcC+dvcC+hvcE
Audio
Codec ID                                 : ac-3
The problem is that the Audio is delayed, I went through the forum and found I had to to use dovi_tool, how do i proceed..?
staknhalo
Post by staknhalo »
Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
Happy P8 making :)
Post by Manixx2020beyound »
@ quietvoid
L2 meta keep coming out weird.
But on the xml it seem to be correct well (not 100% sure it’s correct.)
What could be the reason for this?
Just curious if u got any insight on this from others ellse were
So far I get a perfect l1DV meta match from resolve min-average-max are all correct
For spares & munsil compare to the original
quietvoid
Post by quietvoid »
Manixx2020beyound wrote: Sun Sep 12, 2021 4:49 pm @ quietvoid
I don't know, I've mentioned that the L2 doesn't always match in the RPU.
My only test samples are Netflix's encoded streams, and the corresponding CMv2.9 XML.
Sometimes it's fine, sometimes the values are different.
